Results 1 to 2 of 2
Thread: Removing Panel Under Steering Wheel
    Oct 2006
    Yorkshire
    Default Removing Panel Under Steering Wheel
    Hi
    Does anyone have a link or any details on how to remove the lower panel under the steering wheel on an 04 vectra?
    Need to remove it to run a Mic wire in for a Handsfree carkit
    under the column shroud is 2 x torx in each corner.. extend the column and push it right up to access them..they are quite deep back but you should spot them
    then a row of 3 screws under the panel down by the pedals..stand on your head in the footwell and you'll see them..
    and finally one hidden by the light switch.. you'll need to remove that to get to the screw..push the light switch button in and turn till it clicks and the switch pops forward. then just pull it out and you'll see the screw..
  1. Removing steering wheel
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2012, 19:03
  2. Removing Steering Wheel Trim
    By CraigoT in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 08:03
  3. For Sale: Trim panel for under steering wheel
    By Kev_A in forum Parts for sale
    Last Post: 26th August 2011, 23:04
  4. Removing Steering wheel buttons
    By BigWilko in forum Styling
    Last Post: 5th January 2011, 10:54
  5. Removing trim from steering wheel
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 22:07
how to remove the interior under steering wheel vectra c
vectra c steering column shroud removal
vectra c steering wheel shroud removing
how to remove cover under steering colume opel sepira
vectra c remove panel under steeringwheel
removing cover under steering wheel corsa c
remove lower steering trim crosa vxr
astra vxr remove plastic under steering
steering wheel Vectra C
astra j remove panel under steering wheel
astra h panel under steering wheel
astra h lower steering trim removal
vectra 2009 plastic fitting under steering wheel
astra h under steering wheel trim removal
removing the under steering wheel under trim from an astra twintop
vauxhall corsa d steering wheel column cover removal
