Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: where to buy a new inlet manifold
  1. #31
    N Ireland
    Can someone convince me that after doing close to 140k with the swirl rod missing, I should still replace this part? car is going very well after dpf drilled through. It's had its sensors cleaned/maintained over the years when thing have got lumpy and that has seen me through the miles its covered to date. Am I missing something?
  2. #32
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by naut1que View Post
    It all depends in which position the swirls are when the bar falls off. If they stick open then you will have issues, but if they are shut then you'd be fine.
  3. #33
    Nov 2012
    northwest
    quick queation related to this. if i have my egr mapped put will the dpf not show an error code
  4. #34
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by faz123 View Post
    Do you have a DPF? Usually auto's and estates have them?
    If you do then that can be mapped out too
  5. #35
    Nov 2012
    northwest
    cheers pal. ill.check
  6. #36
    N Ireland
    I got a long sds drill bit and put 5 or 6 holes through my dpf before blast out any debris with compressed air (also compressed air down the vacuum hoses on the side). Its running great now for almost 10k miles. Light on dash but doesn't impact performance afaics and smokes a bit at times on acceleration but not as bad as some have mentioned
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
