Results 1 to 10 of 13
Thread: Limp mode at 2750 rev - 2.2 SRI Diesel.. help
    Bolton
    Default Limp mode at 2750 rev - 2.2 SRI Diesel.. help
    Hey,
    I have had a problem with my 2.2 SRI DTI for over a year now.
    At first it was black smoke from the exhaust - seemed to sort this with a simple EGR clean out...
    However, i have no power at all in the car, especially when i come to a hill! I pray that i make it over!
    It seems to cut out at 2750 revs.
    I have changed the inter-cooler hose as it had a huge tear, runs slightly better now under the 2750 revs but still cuts me out once I go over (unless I am in the higher gears, it seems to let me reach 3500).
    Any help would be great...
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Could be split boost pipes
    Bolton
    Cool - thanks
    Just found this after your comment so will give it ago
    http://www.vectra-c.com/forum/showth...ded)&p=1304107
    Fingers crossed!
    Aug 2012
    My turbo was going and after some research I found that I could set a code (spanner etc) by revving to over 2700 for more than 4 seconds. Mine was due to a shagged turbo but as already said damaged boost pipes could also be an issue. The other likely candidate is the Variable vanes in the turbo being clogged and not spinning up the turbo as it expects. This is usually due to short drives with little use of the turbo.
    Bolton
    I have ordered all the pipes as the thread shows in my last post... hopefully arrive this weekend so i can fit them.
    I drive over 40 miles per day (motorway) so the boost was always in full swing.
    Can you 'de-clogg' the variable vanes?
    Once i have done the pipes i will pop an update on here with the outcome.
    Aug 2012
    Well one thing I have learnt about the turbo on the vec is that it has a few different bits and if I need another new one in the future I will only be buying the CHRA part and fitting it to my existing turbo housings. Anyway the Vanes can be cleaned but you would have to disassemble the Turbo to do it. To be honest the only reason I said it is because having fitted my new turbo I was worried I may use it to much too soon. However the recon guy said use it normally and make sure its used. He said any journey without much boost would allow carbon build up that will / can reduce the vane deflection resulting in unexpected pressures for a given input.
    Bolton
    If anyone can still help?
    I have changed all boost pipes including the intercooler ones
    The EGR has been cleaned out
    The Throttle body & Boost sensor have been cleaned out
    I am looking into the turbo vanes but think thats a garage job...
    The fault codes have been cleared but i am always left with code - P1483-04 Fan control circuit open
    I have ordered a new boost sensor so will give that ago next week.
    The car has handled a lot better and seem to have some power back (can over take) but as soon as I hit the 2750 revs or put it under load on a hill - limp mode!
    Love this website and sure there is someone on here that has had the same issues.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Aug 2012
    Have you fitted a new boost (MAP) sensor now? and have you sprayed all the pipework and intercooler with soapy water to ensure no leaks?
    Bolton
    Thanks for the link Steve - i have done everything on there except the Turbo vanes & lowering the boost etc... will look into that one.
    James - got a new MAP coming this week so will be popping that on ASAP... I have already changed all my intercooler & boost hoses as they nearly all had a split in them!
  1. Can limp home mode correct itsself? 3.0 turbo diesel
    By malk in forum Vectra C / Signum Troubleshooting
    Last Post: 15th August 2012, 06:52
  2. Limp mode
    Last Post: 14th August 2012, 17:23
  3. car going into limp mode 1.9 150
    By bingo999 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 19:30
  4. Diesel running in Limp mode.
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 21:29
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
