Results 1 to 10 of 11
Thread: HIDs -facelift? confused
    Regular Member kalioon's Avatar
    Jan 2012
    Scotland
    Default HIDs -facelift? confused
    little confused between the pre and post facelifts and how canbus interacts.
    If i want to put HID's in my 06 facelift veccy, do i just stick H7 bulbs in? or do i need the full kit; ballast, cancellers etc?
    cheers
    Full Member
    South West
    You will need the full kit mate. I think there might be some exceptions if the Bi-Xeon is activated in the menus using Tech2, but i have got the full kit installed on my 06 Facelift.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    u need ballasts and bulbs, most nowa days come with cancellors bulit in,these are the ones i have, recommened by a good few people on here.
    you will want 4.3k or 5k which is colour, 4.3k is white white with just a hint of blue, 5k is white with a little blue thru it, if u got 6k which i wouldnt looks tacy and may get u a pull buy the screws is quite blue and 7k is purple.
    http://www.hids-direct.co.uk/h7-50w-...nbus-hid-kits/
    where abouts in scotland are you from??
    11 Post(s)
    Quote Originally Posted by rozzer2006 View Post
    Had my 6K HIDs in for just over 3 years now. Never got stopped by the filth for them, and whenever I've been pulled over for other reasons they've never commented on them, nor has an MOT tester.
    Mine are mainly white, with a very light hint of blue. Certainly not tacky, but 8K onwards would be IMHO.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Agree with the above, used 6k on my old astra coupe and they are now on my vec too!
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Quote Originally Posted by Neve'o View Post
    What bulbs you got in your mains,I got 6k hid's and i know I'll never get a perfect match but I can't seem to get anywhere near bt the moment everything I put in looks very yellow even though they're described as white when you buy them
    Norfolk
    Mileage : 69'000
    The only way you will get a perfect match is to fit HID's in the mains, had this in my coupe but for the vec I'm using night-breakers which although yellow compared to the HID's they do a good job.
    Jan 2012
    Scotland
    Thanks chaps. thats cleared that up.
    im in fife btw.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    to be honest i had 6k's for 6 years and never had any problems but since getting the 4.3k's i think the 6k's are a bit too blue, but its up to you.
    ah bit to far away from me coulda helped you with em.
    If you do do it, ure going to need to drill a 20-25mm hole offset/to oneside on the cover, because of the wires that stick out the back of the bulb. make sure its a goot fit and and a good seal so the headlight doesnt steam up. and to save you cutting wires pull the spades thru the rubber gromet. then put the bulb plus thru the holw and then put the spades back thru the gromet, if ure confused it should make sence when you get them if ure still having trouble ask on here or PM me al send you some pics of mine.
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    What are most folk using 35w50w 55w i have 35w ones and 1 bulb as gone so im thinking of getting a new kit but dont know which one
    gaz
  1. Advice on hids please : 06 facelift vec
    By Envy in forum Styling
    Last Post: 3rd February 2012, 00:51
  2. hids preface to facelift
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 5th August 2011, 01:28
  3. Hids on a facelift
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 18:25
  4. Facelift HIDs query
    By johnny1983 in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2010, 21:36
  5. retrofitting HIDS to a facelift Vec C
    By glasgowrob in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2009, 18:22
