Thread: Must push Accelerator when car is warm to start. Why??
    Aug 2010
    London
    Default Must push Accelerator when car is warm to start. Why??
    When the car is warm, i have to push the accelerator to get it start. It struggles but starts.
    Once started i have to keep the revs high for a few minutes untill there is a slight change in the car and then i can let the revs drop. Once the revs drop the car runs perfect. Idels perfect also.
    The car seems to start perfectly when cold and first time also.
    No engine lights are showing either.
    Any idea what is causing this?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Get codes read.
    Fuel filter changed? Checked all connectors all fitted? What engine/spec etc
    Aug 2010
    London
    Hi,
    There are no codes. the car is a 2003 vectra c 1.8 16. I have released the pressure in the fuel pipe and there was plenty that came out. Car also started ok after this test.
    connectors seem to be ok also. could this be linked with the engine coolant temp sensor located beside the thermistat?
    i have changed MAF, Oxygen sensor after cat, cleaned teh throttle body. EGR valve replaced not that long ago. Spart plugs cleaned.
    any help would be great.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Injectors staying open
    Jan 2012
    Silverstone village
    So its fine from cold with no issue? , but when started after warm it fails to fire straight away?
    Hmm , I'm guessing air is entering the fuel system some where before the injection pump, and that this is only when left with warm/hot fuel in the lines.
    Does the CDTI have an electric lift pump?
    This is only a huntch
    Edit , injector sounds more likely.
    Aug 2010
    London
    how can i check for this? does that not mean the car is getting to much fuel then?
    Urm the car is unleaded. I think it does have an electric lift pump though. yea the probly only accurs when the car is warm. It trys to turn over a few times and then starts and i must keep revs high for a few mins then everything ok. If i dont it stalls, or lack of power and then stalls.
    Jan 2012
    Silverstone village
    Quote Originally Posted by Tank988 View Post
    The injectors will not be sticking open all the time or you would be calling the car smoky Joe... lol
    If the injectors stick open when the engine is turned off, the fuel would drain into the cylinder and leave air in the high pressure injection pipes, this needs to be cleared and filled with fuel before the engine will fire, holding the accelerator down will open the injectors for longer and inject more fuel, or in this case purge more air from the lines , until fuel gets to the injector and she fires.
    I'm just wondering why this wouldn't happen when cold after being left overnight..?
    Aug 2010
    London
    Over night is the best. ant had any problems starting the car at all when cold. (i did for a while have problems starting the car in genral with it misifring etc but i replaced MAF, o2 sensor cleaned throttle body) and now im left with this problem just.
    Is there an easy way to check the injectors to make sure they are clean and working??? maybe worth a cheack if its easy done??
    Thanks Guys
    Jan 2012
    Silverstone village
    If I were you;
    1) I would run through some injector cleaner for the cost of it, might de coke an injector.
    2) Then change the fuel filter, If the filter is clogged it can be easier to suck air into the injection pump than pull fuel through a dirty filter.
    3) Get injectors tested by a specialist.
    Thinking on I reckon the fuel filter! , hot fuel is allot thinner than cold fuel and so its easier to get air leaks on the vacuum side of the fuel lines.. generally between the fuel filter and the injection pump as this will be the greatest vacuum especially so if the filter is clogged.
  1. Has anyone else successfully fitted a push start button?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2014, 09:00
  2. Push Start Button
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2011, 12:41
  3. do you own a Keyless entry push button start car?
    By hoochydady in forum General Chat
    Last Post: 9th March 2011, 20:10
  4. Vectra wont start when warm!
    By haye5 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 17:29
  5. Vec C Push Button Start?
    By arbell in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2010, 00:51
start from warm requires to push accelerator
