Results 1 to 2 of 2
Thread: Heater matrix control flaps
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Heater matrix control flaps
    Here do i find this? Both inside the air flow unit in dash and maybe one in engine bay?
    Basically i want to access to see if its opening and diverting air flow the heat from the matrix to air vents. The dials are fine. Matrix is not blocked. The control arm operating from the dials and also operates the flaps that divert the air flow by the control motor from the dial.
    Dials hot/cold ----> control motor (red lever) ----> flaps next to matrix
    Driver side only access matrix. Where else do i access to check them flaps to make sure it is connected to arms that rotate flap operation. As i have a feeling its broken or basically dislocated.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    No one got a clue? Looks like i'll have to remove sides and see if i could access then:-(
  1. heater matrix
    By strothrc in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:31
  2. Heater matrix!
    By SUBEK in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 15:43
  3. heater control flaps
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2010, 19:19
  4. Need help with the heater matrix on my vectra c
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th December 2010, 22:32
  5. Heater matrix now done
    By adfrodsham in forum Bodywork & Interior
    Last Post: 24th February 2010, 23:00
vauxhall vectra heater matrix flaps
