Hi all,
Sorry if this has been posted before, but I can't figure what to look at first from reading the other posts.
I have an 04 reg 2.0 dti with Y20DTH engine.
I get the spanner light and limp home mode on almost every journey now. It only happens once the car is getting up to temperature. If I turn the ignition off and start the car again the car runs fine for a while with no error lights, but because it is already warm the spanner light returns again.
The problem generally occurs under acceleration, particularly when going up hill. I think I can hear a slight hissing noise as well.
A couple of times the engine has actually cut out, although there was no error light when that happened.
I have a code reader and get the P0100 code indicating a MAF problem.
I have read that there could be a problem with the MAF sensor, wiring, vac pipes and egr valve.
I was wondering if with my cars symptoms what is the most likely cause and is there a possibility I have missed?
Thanks in advance for any help.
Cheers
Kenny
