Thread: P0100 most likely cause for these symptoms
    Regular Member brotherkennyh's Avatar
    Swadlincote
    Question P0100 most likely cause for these symptoms
    Hi all,
    Sorry if this has been posted before, but I can't figure what to look at first from reading the other posts.
    I have an 04 reg 2.0 dti with Y20DTH engine.
    I get the spanner light and limp home mode on almost every journey now. It only happens once the car is getting up to temperature. If I turn the ignition off and start the car again the car runs fine for a while with no error lights, but because it is already warm the spanner light returns again.
    The problem generally occurs under acceleration, particularly when going up hill. I think I can hear a slight hissing noise as well.
    A couple of times the engine has actually cut out, although there was no error light when that happened.
    I have a code reader and get the P0100 code indicating a MAF problem.
    I have read that there could be a problem with the MAF sensor, wiring, vac pipes and egr valve.
    I was wondering if with my cars symptoms what is the most likely cause and is there a possibility I have missed?
    Thanks in advance for any help.
    Kenny
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Same as my issue. One of the intercooler hoses are split. Or letting out pressure.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Hissing noise is a boost leak. Start by checking all hoses from the air filter to the turbo, and from the turbo to the intake (via the intercooler).
    Maf fault could be nothing, it may be registering wrong due to the boost leak. In theory, the MAF is reading airflow fine, but the engine isn't consuming the air because it's venting out under pressure before it reaches the intake.
    Swadlincote
    Thanks for the info. I will pop it open at the weekend and take a look. The hissing does seem to be coming from in front of the driver, although it's hard to tell without going under the bonnet yet.Oh, and I forgot a symptom, It might not be relevant but the idle speed is slightly higher. I will post back at the weekend with results. Cheers
    Swadlincote
    Hi all, it was the rubber pipe just to the right of the EGR value (as looking at the car). There was an inch long split in it. It has covered everything around it in annoying black crap. I had already ordered a new pipe figuring it wouldn't hurt to change it anyway, a nice blue one. The new one hasn't arrived yet, but I can't see anything else wrong.
    Dec 2010
    ayrshire
    Default please help
    Quote Originally Posted by brotherkennyh View Post
    which pipe is this please.
    i have same issue slow sluggish no power, accelerating takes it into limp mode got code read today p0100.
    i dont want to buy a new maf meter part if i dont have to, i know nothing abut cars, but if anyone can help id apprecciate it as this is naff and the car is using loads more diesel due to it.
    vectra c 2.0dti 68,000 03 plate
    thanks
    craig
  1. PLEASE HELP ERROR CODE p0100
    By signum_05 in forum Troubleshooting
    Last Post: 20th December 2012, 20:20
  2. Fault Code P0100
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st August 2011, 06:46
  3. Flaming P0100 Error again
    By richje100 in forum Engine & Drivetrain
    Last Post: 18th February 2011, 23:23
  4. Fault code P0100, AGAIN!!!
    Last Post: 1st June 2010, 14:20
  5. Fault Code P0100
    By vectra2004 in forum Troubleshooting
    Last Post: 27th May 2008, 19:08
2004 vectra c 2.0 dti po100 problems
2.0 dti p0100 site:www.vectra-c.com
p0100 vectra
