Thread: injector leaking
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    rolleyes injector leaking
    After fitting my new battery tonight and started engine i could hear a strange noise which i hadnt heard before coming from the engine like a spurt of air every second, so i removed the cover and found that no1 injector is leaking (oily all around injector and bubbling when air is released),
    So i will be taking it to my local garage to see what its going to cost hopefully just needs copper washer replacing under injector,at what price i havent got a clue.
    Any ideas on price anyone ?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Approx £50 - £100 depending on labour
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Or a couple of quid for the washers and half hour of your own time...
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Quote Originally Posted by leemarksmith View Post
    A simple job, but i wouldnt recommend doing it yourself incase you 'over cut' the injector seat in the cylinder head, the problem will come back if you just replace the washer.
    Apr 2009
    CO DURHAM
    Quote Originally Posted by XPCobra View Post
    Thank`s Cobra I will be taking your advice and leaving it to the mechanic to sort it.
    Apr 2009
    CO DURHAM
    Thank`s for the reply but the mechanic will be getting the job just incase it goes wrong.
    Jun 2011
    wolverhampton
    We recommend a new injector at work as they lift off the seat as not spraying correctly. Hope it comes out as they can be a nightmare if not. Good luck to ya. Did the wiring or spill pipes look burnt as this can be extra cost.
    Apr 2009
    CO DURHAM
    Quote Originally Posted by sriandy View Post
    No wiring burnt! Phoned my garage this morning and explained and told me it would be £45 plus cost of seals,sounds good to me.
  1. injector no4 leaking.need advice asap
    By will2.0dti in forum Engine & Drivetrain
    Last Post: 8th July 2012, 13:13
  2. Damn car! (150 cdti injector leaking)
    By John LE in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:46
  3. petrol injector leaking!!!!
    By mollers34 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 06:10
  4. noisy and leaking injector?
    By leeky1 in forum Engine & Drivetrain
    Last Post: 15th May 2011, 23:09
  5. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
anyone taken cilinders head off vectra 1900 150
