Thread: ECC air conditioning delay
    Melbourne, Australia
    Default ECC air conditioning delay
    Hi all,
    I've recently noticed a curiosity with my air conditioning and I'm wondering what the explanation may be...
    (Pre-condition: car cold, outside temperature hot, eg. 35° C)
    If I set the ECC to "Lo" ie. unregulated cold, the car will start blowing out reasonably cold air. But it's only after about fifteen minutes that the car suddenly changes to blowing really, really cold air. It's like the car waits until the engine has warmed up before it will fully operate the compressor. I'm not talking about the fan speed - it stays on full from start up.
    Does anyone know what the ECC waits for? (Does my explanation make sense???)
    Thanks.
    Full Member Big Sig's Avatar
    Sounds like its short of gas TBH, get it checked. If you lift the bonnet and listen while someone turns the A/C on and off you should hear a change in engine speed and the A/C compressor engage. The A/C is turned off in "ECO" mode.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Mine does this too .. as it's ECC and it works on temperatures (rather than standard air con which is simply hot or cold) and it knows the temperature of the air it can put into the cabin is too warm it will only feed a smaller amount in until the compressor is up to full cooling capacity.
    Dave
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Like Ukanalyst said... and a comparable delay happens if you want it to heat the car but the engine is still cold... what is at the moment more the case over here ... 35°C
    Nicking Ya Dinner.
    ECC is a bit hit and miss on any car tbh, it's real design strength is when you set and forget when going on a 100 mile + journey, gives it time to fully adjust, as the others have said it reads from sensors rather than the just control panel, when it's used on short journeys it has to overcome several variables, two in particular, opening of doors and windows, and the sensor wont get it right until the sensor decides it's right, I prefer normal A/C myself, with that you get a constant setting, I remember my 1st Omega CDX I had with it, if the sensor decided the cabin had got a bit warmer it'd blow cold air out to re-regulate the temp, not nice on a cold day when all you really wanted was to turn it down one notch, and when it decided the windscreen was misted, Whoooooa it blow like a pornstar.
    Thanks everyone.
    Quote Originally Posted by sig63 View Post
    I guess you're not getting to many 35° days at the moment
    I just realised that it might be that the ECC suddenly changes the air distribution. I'll have to try it with manual air distribution and fan speed to see if that makes any difference.
    Quote Originally Posted by VauxVeteran View Post
    This is the first car I've had with ECC and I'm pretty happy with it. I don't like the user interface - changing the air distribution or compressor on/off setting is way too complicated - but otherwise I think it's quite good.
    It would be nice if the ECC could learn that the quickest way to cool a hot car is to open all the windows for 30 seconds or so...
    Jul 2006
    Cheshire
    Quote Originally Posted by stevedee3 View Post
    It does ... you just need to help it along by holding down the door unlock button on the keyfob 30 seconds before you get in
  1. cd 70 delay
    By slugo in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 18:14
  2. lights on delay
    Last Post: 26th March 2011, 23:07
  3. lights on delay
    By m8wos in forum Styling
    Last Post: 23rd October 2008, 20:43
  4. Trunk delay
    By lucasss in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 23:46
  5. Tuning box..........delay
    By diesel dog in forum Diesel Engine related
    Last Post: 6th July 2007, 00:03
