Results 1 to 10 of 13
Thread: Blimey I've only gone and fixed it!
    Regular Member bennettboy's Avatar
    Havant UK
    Default Blimey I've only gone and fixed it!
    Well having tapped into the wealth of knowledge on this brilliant forum/club, Ive managed to fix the none working temp gauge.
    And as diagnosed it was the stat, so £49 for a new stat and 3 hrs of my time I managed to take on my 1.9 120 and fit it.
    What a nightmare job! dont think the italians could of made it any harder and I thought my old mazda was difficult at times to work on.
    So cheers guys
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    italians??
    Havant UK
    Yep Italians the 1.9 cdti is a Fiat lump.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Nicely done matey
    I received mine yesterday but have no time at the mo to get it fitted. Have to set off for work at 4am and don't get home till 4:30pm so last thing I want to do is get stuck in taking the car apart
    Is it really that difficult to do???
    Might have to bring all my tools home from work then if that's the case
    Jan 2012
    southwest
    Quote Originally Posted by bennettboy View Post
    learn sutin new everyday. cheers
    Havant UK
    Quote Originally Posted by Damo77 View Post
    Nicely done matey
    If you follow the How2 for the 150 you cant go to wrong, biggest pain is the bracket on the EGR cooler that sits on the threaded bottom bolt of the thermostat. I ended up loosening the cooler clamps and the two bolts that hold the bracket on at the back of the engine, and had to basically prise the bracket away as best I could. Then I ended up painstakingly undoing the bolt with a spanner and eventually got it out. Some people have cut the bracket off the egr cooler, I ended up hacksawing the threaded bit at the front of the bottom bolt and left the bracket on the cooler.
    No doubts there is an easier way but I couldn't find one. Good luck with yours but its worth it in the end.
    Year : 55
    Mileage : 92,000
    Will have a read of the HOW-To in a little bit, many thanks for the heads up regarding the bracket.
    Might get my air grinder from work then and cut the offending bracket off
    Damo
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    That's the Italian way, never give up - oh, wait...
    Nov 2010
    East Midlands
    Trim : design
    Damo
    Its difficult to get anything in to cut the bracket off until you have removed the stat housing - can't really see what the bracket is there for it is still rock solid without it
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Dont cut it!!! Just bend it outwards! When refitting, bend it a bit so the nut can bend it back to shape as u tighten!
  1. Blimey, that was quick
    By Andyjarvis in forum General Motoring Chat
    Last Post: 12th March 2012, 14:32
  2. Blimey!!!
    By DTGB in forum Handling & Braking
    Last Post: 10th November 2009, 21:08
  3. Blimey..I can hear my engine now!
    By bennettboy in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2008, 23:39
  4. Blimey how many birthdays !!!!
    By Drinky in forum General Chat
    Last Post: 1st January 2007, 23:57
