Results 1 to 10 of 13
Thread: Vectra 3.2 Losing Coolant :(
    Nov 2012
    Leicestershire
    Default Vectra 3.2 Losing Coolant :(
    Hi all, firstly I would like to say hello to everyone here as I'm a new user
    I have a 2004 Vectra GSI 3.2 and as the title states it's been losing coolant. The car doesn't overheat and there is no mayo on the dipstick etc but I'm having to top the coolant up every 40 miles or so. I had a sniff test done last week and apparently all is ok.
    I changed the coolant last week and flushed the system as it looked very orange and rusty but within a few hours it had become cloudy again. It's not thick or creamy, it's just cloudy.
    Could it be the headgasket or does it sound like the oil cooler?
    Many thanks in advance
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The anti freeze is an orange rusty colour, what anti freeze did you use to replace it?
    Nov 2012
    Leicestershire
    I used Halfords Advanced Antifreeze & Coolant ready mixed to replace the old coolant.
    newport
    not a leaking coolant bottle is it? isnt that common on the vec c around the seam or is it the vec b?
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    That is OAT antifreeze, which is what is required, but unless you managed to remove all the water from the flush there is no way that will be strong enough to protect the engine against frost protection and aluminium protection. -28 is the minimum protection required.
    Anyway, One of the weak points of the vec cooling system is the header tank, they can split at the rear of the tank, just a hair line crack, but when the system is pressurized its enough to loose coolant. I take it it was loosing coolant prior to your coolant change?
    Nov 2012
    Leicestershire
    It's a Vectra C. I can't see any evidence of coolant around the expansion bottle and the bottle is pressurised when hot.
    Nov 2012
    Leicestershire
    I removed the header tank from the car to clean it and I couldn't see cracks or damage. The car was losing coolant before I did the flush etc. What puzzled me though that after a few hours I could see a cloud forming in the header tank. If I squeeze the large coolant hose, there was this cloudy coolant appearing in the tank.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    ive seen a few threads on the 3.2 v6 losing coolant
    ill see what i can find
    http://www.vectra-c.com/forum/showth...losing+coolant
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
  1. It appears it's losing coolant now
    By Celes in forum Y & Z30DT Specific
    Last Post: 19th November 2012, 14:18
  2. Losing coolant but where??
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 12:27
  3. losing coolant
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 22:30
  4. Losing coolant
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:44
  5. Losing Coolant
    By parapaul in forum Engine & Drivetrain
    Last Post: 7th November 2008, 09:55
coolant change vectra 3.2
vectra c rusty coolant hose replacement
