Thread: Key Fob works intermittently
    Sep 2011
    Paisley
    confused Key Fob works intermittently
    I have a Vectra 52 Plate 2.0DTI Elite.
    Been having this problem ever since I got the car and not sure if its the keyfob or the immobilizer that is at fault.
    Basically when I leave the car and go to lock it by pressing the button on the key, the key doesnt do anything. I then have to reinsert the key into the ignition and long press the open button on the fob for it to resync to the car.
    I then leave the car, close the doors and the car locks no bother. Then the next day when I try to open the car with the keyfob, nothing happens (but my LED sidelights start flashing so I can tell that the car senses a remote signal, just maybe not the right one). I then have to open the car with the key in the door, which sets the alarm off until I insert the key in the ignition, and the whole process starts again.
    Can anyone tell me whether it would be the key which needs replacing or anything else that it could possibly be? Can't find anyone else thats had the same problem on here.
    Thanks.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Start by replacing the battery in the key
    11 Post(s)
    Try placing a thin piece of card (or folded up post-it note) on top the battery before putting the cover on. Not unknown for the battery contacts on the PCB to become loose. The thin card helps make a better connection.
    It's not immobiliser related as that doesn't use the battery in the keyfob, and the alarm wouldn't silence when you put the key in the ignition.
    Sep 2011
    Paisley
    I've already checked and replaced the battery, its fine. The fact is that I can sit in the car, lock and unlock the car with the fob, then after a couple of times it stops doing anything and I have to place it in the ignition again, turn to position 1, and press the unlock button on the fob. Then it will work for another few times.
    Cheers bigdave, I will try the card trick and see if it works.
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    168 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Hi m8. I had a "similar" issue with one of my keys. All it needed was "re marrying" to my car with one of the gadgets that can do it, tech2 , vauxcom, and others. If you get the chance, try that option too
    Regular Member neil52's Avatar
    Oct 2012
    leeds
    ive just had same thing i got a new key cut, but i put the folded paper at back of battery and it works fine now i was having same problem but also car wouldnt start.so ive 2 keys flip one and a normal one.
    Sep 2011
    Paisley
    Cheers to Big Dave, i put a folded up piece of card on top of the battery, forced it shut, then put the key blade back on, button feels alot tighter when pressing too and the remote works perfect every time now!! and here was be about to buy another key!!
  1. Front end knocking intermittently
    By shb1988 in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 21:13
  2. Replies: 23
    Last Post: 17th November 2012, 23:49
  3. Steering intermittently heavy at low speeds
    By SYMON in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2012, 15:10
  4. passenger HID not working intermittently
    By n8sby in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 15:26
  5. Stereo - sound intermittently breaking up
    By johnmac in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2006, 09:05
vectra c key fob intermittent
vectra c key fob intermittently
remote key fob vectra c dont always work
vauxhall corsa key fob works intermit
vauxhall combo intermitent remote
car key fob works intermittently vectra
vauxhall vectra 1.9 cdti key fob fault
My vauxhall key fob working intermittently
intermittent key fob working
vauxhall zafira key fob
PIC OF VECTRA C CAR KEY
