Results 1 to 10 of 14
Thread: EGR pros and cons
    Nov 2012
    northwest
    Default EGR pros and cons
    hi all i have a check light on caused by the EGR ive done a bit of reading and seen how to clean it but my question is what the pros to cleaning it and leaving it on and the cons to taking it off?
    cheers
    Jul 2011
    UK
    Year : 06
    No cons just don't loose the gasket pros daylight prob go off and ur car will run more smoothly and saves ya manifold
    Nov 2012
    northwest
    so take it off or leave it on
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by faz123 View Post
    I personally would take it off, or rather leave it on, but blank it.
    With it blanked (assuming no other issues present) then the pick-up will be much smoother and quicker, less smoke too, but you will get the spanner light for a short time and be left with the emission light on (the little engine symbol in the bottom right corner) - this is now an MOT failure, so would need to either get it remapped out, or remove the blank a few days before the MOT and refit after.
    Nov 2012
    northwest
    dont know if it matters but the swirl bar is also disconnected. didnt relly wana start mapping and modding. been there and spent too much money lol
    Lancashire
    Trim : XP1
    Mileage : 66000
    The ****e the EGR feeds through will have gunked up the swirls and caused the bar to come off. Some on here have managed to get the bar back on, some remove the bar and stick the swirl valves open - others replace the manifold, its upto you which road you want to go down, but either way it will need sorting one way or another.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    swirl bar will have fallen off because of all the crap the egr lets through you can glue them open or replace the manifold mine was the same I chose to replace the manifold all I can say is i wish my wife was that dirty but glad shes not that smelly
    Replace manifold with upgraded one, blank egr and get a remap to give you more power/torque and map out the EGR. You can't physically disconnect it because the software still looks for it and needs to know its there. If it isn't, it puts the emissions light on again. The map causes it to remain shut and the fuelling is adjusted to suit that, but the valve still needs to be there.
    there are no down sides to this solution, except the possible increase in insurance due to the remap. You can get it mapped out without the increase in power, but where's the fun in that...
    Nov 2012
    northwest
    cheers . i was palnning on sorting the egr out on satday. how the fck do ya get into the swirl bar thou couldnt even get a finger in there last night, has the IM gota come off to sort the swirl valves out until i get a new IM also is it a diy job or garage. IM removal dosnt look as simple as on my hyundai
  1. Pros and cons of mapping.
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 08:16
  2. 255 or 280. Pros and cons.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 18:59
  3. Pros and cons of an automatic?
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2010, 10:36
  4. The pros and cons of another marque.
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 12:39
  5. Should I fit a CR1 - what are the pros + cons
    By ballogie in forum Diesel Engine related
    Last Post: 19th January 2007, 19:57
