Results 1 to 10 of 11
Thread: Gearbox Help Please
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Default Gearbox Help Please
    Hi
    Nipped out last night and on the way back changing gears seemed quite clunky, got home slipped it in neutral moved the gear stick and there is no resistance there at all, it moves easily from side to side.
    Any help or advice on whats caused this and how to fix it would be great.
    Thanks in advance
    Donna (1.8LS petrol)
    Mileage : 000
    Has any of the linkage on the gearbox come off or come lose.
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Im not sure because i havent been able to get under the car, and to be honest ive never had to do anything to the gear box before so wouldnt really know what im looking for. Will find an image and compare the two.
    Mileage : 000
    O mine you can see some rods or cables on the top of the gear box. From looking in the engine bay.
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Thanks Ed
    Ive checked and I can see what you talking about, but I cant see that anything has come off or seems loose
    Mileage : 000
    Might be something at the gear stick end. But. I would have thought that would affect all gears.
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Its moves too freely in neutral and towards each gear then seems to clunk into gear. All gears are the same.
    Ive looked in the manual and seen how to remove things to get to the gear stick end so I'll try that.
    Thank you
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Took the gear stick end to pieces in my lunch break today and can see the problem. To the left of the gear stick there is like a spring that has a hard plastic cover on each end. One end has snapped just as it goes inot the plastic....pics below
    Guess my next questions are, what is this called and is it easy to replace?
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    I have just spoke to a vauxhall breakers in Leicester and he reckons i'll probably have to replace the gear stick. Can anyone tell me if thats correct?
    Thanks in advance
    Donna
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Looks like it might be easier to replace the gear stick.
    CLICKY HERE
    Easier than messing on with a snapped bit of plastic, unless you can do a temporary repair so it's driveable ?
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
vectra c gearstuck spring broke
