Results 1 to 10 of 16
Thread: Interior Light Issue - Light & Button Illumination?
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Interior Light Issue - Light & Button Illumination?
    Anyone know of any known issues with the ribbon block on the interior light or an issue with dim or unlit buttons...
    I've had an issue with my buttons not illuminating, or having any power whatsoever (so not turning light on etc) since fitting my rear light and footwell lights way back, so i assumed i'd slit the ribbon in the roof lining etc but something weird happened today...
    I Got in the car after work and the buttons where lit, as i drove they dulled and lit etc, buttons would put the light on also and the only thing that's different is I dropped the roof lining to check all the length of the ribbons (all perfect) and fit a new aerial base this weekend, so...
    Would a dodgey earth effect the buttons, or are the blocks weak if removed regularly and heavy handedly... Anyone had anything similar, how did you solve it?
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    you tried light out of black un Lee?
    18 Post(s)
    Mileage : 110k
    Rear lights fine, and the front/rear lights still come on with the fob/doors opening etc...
    It's just the lit buttons and the fact they don't work when not lit... Weird.
    Jun 2009
    bradford
    did you say you changed the ribbon?
    18 Post(s)
    Mileage : 110k
    No, i just checked it as i assumed i'd accidently cut into it releasing the rear light ribbon as it all went at the same time...
    If my wiring for the footwells is causing it as i cut into the earth, then surely the full lot would not work, yet its only the button illumination & the fact the buttons don't work when there not lit...
    Jun 2009
    bradford
    when I removed mine I nicked the ribbon with the retaining screw and every now and then I was getting flashing etc from mine, loosen off the screws and see if cures as my screw was causing a short
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    What bulbs do you have in the rear lights??
    My front interior lights went crazy after trying to fit canbus safe LED bulbs in the rear.
    I had Canbus safe LED's fitted in the front interior and map lights with no problems.
    Then I tried to use the same canbus safe LED's in the rear lights and the whole lot went crazy.
    So I have to use ordinary bulbs in the rear light to get the front lights to work properly, so I now use Mtec 501's in the rear which are a blue bulb.
    18 Post(s)
    Mileage : 110k
    No its not that...
    But in your case the rear has a weird polarisation issue when it comes to LEDs, if the ones your using have 2 terminals either side you need to remove a + and - from opposing sides and it'll be fine... Only found that out after a lot of head scratching, still no idea why it causes a short tho?
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by hairy31 View Post
    Just realised you wrote black, not back pmsl... I'll try that tomo ha
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Wow, now that makes sense, the metal electrical contact that holds the bulb shorts out both sides of the led bulb.
    Cheers, I will try again. But strange that no fuse blew....
    I will try again tomorrow with the LED bulbs.
    Quote Originally Posted by leemarksmith View Post
    No its not that...
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  3. interior light switch illumination?
    By Mikecdti in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 22:19
  4. Interior Light issue
    By Vectrarmand in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 17:14
  5. Interior 4 button light + Sunglasses Holder
    By Stu14t in forum Parts for sale
    Last Post: 6th June 2008, 19:02
