Results 1 to 10 of 13
Thread: Internal led strip question...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Internal led strip question...
    http://www.ebay.com.sg/itm/ws/eBayIS...m=230828235976
    Anyone advice where do i tap into the internal light to make LED strip light up when open door etc, as want to install led strip lights same colour as the link ( hong kong! Rather be from uk) and i plan to wire up to front footwells and rear footwells as well.
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    The solid brown & brown/white will do it...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by leemarksmith View Post
    Where? The wiring loom in roof lining is flat type.
    Jul 2011
    UK
    Year : 06
    What I have done is really easy take down the interior light and take out a bulb holder they just twist now remove the bulb and put a wire down the sides of the holder on the connections and put bulb back in so kt jams the wire then just feed to ya led
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by Humourbash View Post
    Theres 2 inch worth of wire between the ribbon block and the circuit board if you drop the light... The bulb holder way just doesn't seem as permanent to me, much prefer to solder in to the wires...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Yeah better to solder on, will look tomorrow, just need to work out how to do the roof lining for rear area so theres one strip in that area. Should i make holes or dont do rooflining?
    I know i dont have the bracket already in place in the estate. Cos its dark now, getting annoying that its dark to put harness on our baby in chair.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Speaker cable wires be ok for this set up? 50 metre worth or less?
    18 Post(s)
    Mileage : 110k
    Yeah i used speaker wire...
    You can drop the roof lining to see if you have the rear light ribbon, if not use the same feed and put the speaker wire to a rear light also, can remember the exact pins for the rear light (if buy the gen vauxhall one) but there's 4 to choose from and a thread for retro fitting the rear light is flying about somewhere without pics IIRC...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Can i use ...
    http://www.ebay.in/itm/-/130718979660
    To connect the wiring up? This is without soldering the wires.
    Maybe you could show me one that'll be better as i'll need to make 5 wires to go to 5 areas from 1 wire. Or use a block to connect them all up?
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    I connected mine to one of the bulb holders for the 2 main internal lights, one wire per side and then added a second from the connector block that I put in the footwell to the rear. Ran the wires under the headlining, down the side trim to teh front footwells. Then alomg the side of the sills to the rear seats. Speaker wire ans standard chocolate block connectors did the job fine.
  1. Boot strip question
    Last Post: 18th September 2012, 07:30
  2. Another boot strip question
    By Hyperhart in forum Styling
    Last Post: 1st July 2012, 16:07
  3. CD70 internal fan
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 10:41
  4. Help with where to buy internal doors
    By Critch in forum General Chat
    Last Post: 21st May 2012, 18:17
  5. Internal trim..
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2010, 11:36
