Results 1 to 10 of 11
Thread: 2.0 DTi - not starting properly
    Nov 2012
    Birmingham
    Default 2.0 DTi - not starting properly
    Hi all,
    New member here, recently bought a Vectra DTi (2004 Design).
    Basically, when I start the car, it takes quite a lot of cranking and foot on accelerator to get it going, although when the car is parked at an angle (i.e. one side on kerb, or facing downwards) it starts straight away. Also, I was coming home at 5am once and it was freezing cold, around 2 degrees and it started straight away. I presume the glow plugs are fine.
    Can anybody shed any light on this? The car will be going to get repaired soon but I just want to know what fellow Vectra owners think.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    ok here goes.....first off when starting from cold does the car spanner light stay on for about 45 seconds then go out? if so then your glowplugs aint working properly. one or more are fubberd
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Injector Leak-off pipes, check for splits, cos if it starts fine parked facing downhill, that's where i'd look.
    Nov 2012
    Birmingham
    Quote Originally Posted by Signum-Steve View Post
    No. When starting from freezing cold winter temperature it starts perfect with no problems. It's just when it's not freezing or if I go somewhere, switch it off for around an hour and come back. I have to keep the key turned and foot down and it'll eventually start. White smoke also comes out from the exhaust, visible from rear view mirror. When it's actually on, it's fine.
    Aug 2012
    maybe crank sensor starting to fail.
    Nov 2011
    Quote Originally Posted by jamesmcuk View Post
    Would only generally present itself if the engine was hot
    Nov 2012
    Birmingham
    How much would you expect to pay to get the leak off pipes sorted? Including labour?
    Nov 2011
    about £10-20 for the tubing and t-pieces, maybe 30 mins labour?
    Can be done DIY
    Nov 2012
    Birmingham
    Quote Originally Posted by MrDerv View Post
    Can be done DIY
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Leak off pipes.
    There's also a software update available for the 2.0 DTi that changes the glow plug timings.
    ---Sent from my iPhone 4 using Forum Runner
  1. guide to washing my car properly?
    By vectra3.2dave in forum Detailing and Car Care Discussion
    Last Post: 18th January 2010, 18:22
  2. When woman want clean the car properly :)
    By tommyk999 in forum Comedy & Humour
    Last Post: 31st July 2009, 22:19
  3. Now washed PROPERLY!!!
    By Caterman in forum Quick Photo Album
    Last Post: 24th December 2007, 12:33
  4. Saying hello properly
    By VXR_DV in forum Introduce yourself.
    Last Post: 9th January 2007, 14:42
