Thread: plumbing question - ball cocks
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Default plumbing question - ball cocks
    guys, the ball **** valve in one of my loft tanks is giving up the ghost and I have water leaking out the the overflow to outside (as its supposed to).
    I am looking at some replacements and there seems to be a an option or two.
    My main question is, do i need a low or high pressure version?
    Whats a good price and are there any types/brands that are to be avoided?
    EDIT: i bet they don't block the word on a plumbing forum.. no real need to on here now as the main one appears to be moving on.. lol
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Tanks in the loft are usually refilled from the rising main so will need a high pressure valve.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    This is what you need Nige you would be just as well changing the Ball float also ....you could try cleaning the float valve thats leaking as sediment and gunge accumulate on it and stop it working correctly >>>>>> http://www.screwfix.com/p/pegler-pre...e-part-1/90110
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    It'll be the rubber perished so either replace the rubber stopper or a replacement. Brass type will be more ideal than plastic and plastic might be recommended but i recommend brass ball valve. Best to get like for like as some ball valves are specific to type of tank or type of system. If this tank is expansion tank via combi (dual system) then it'll be low pressure, if water storage it'll be high pressure but get like for like. This way you dont make any mistakes.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Also ideal to have the ball replaced, but you can get new valve as it'll come completed. This way it'll last a long time. Reuse the ball and it'll perish one day! Fills up with water and allow flow to continue and all water wasted at overflow pipe!
    Jun 2009
    South Coast
    i have just gone over it with a wire brush and cleaned it up a bit. Water is no longer pouring onto my patio. Now it has been doing this for a few days but only seems to start once the central heating system kicks in.. its got a 2/3inch connection
    it looks just like this sucker but with a red ball
    http://www.screwfix.com/p/pegler-pre...e-part-2/27627
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Caveman_nige View Post
    What u got is feed expansion tank. Low pressure. Get the ball set to lower level, or replace it. Its only to feed the central system, not drinkable.
    B&Q will have that item if u need it urgent but best to get it replaced asap to prevent water wastage and water bill going up!
    Jun 2009
    South Coast
    will look at getting one very soon, i don't have a water meter so no bill issues to worry about it.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Lol. It wont affect the system but be annoying tho. The rubber will be a cheap altnerative to replace whole thing!
  1. Fighting Cocks
    By Bigglesfliesundone in forum Comedy & Humour
    Last Post: 29th February 2012, 09:33
  2. Emergency plumbing question
    By craigbarlow18 in forum The 'Off Topic' room
    Last Post: 4th January 2009, 20:58
  3. Small Plumbing Question
    By Damian in forum General Chat
    Last Post: 15th May 2008, 19:52
  4. plumbing advice
    By John35 in forum General Chat
    Last Post: 20th August 2007, 22:02
