Thread: Clutch + DMF + master + slave cylinder
    Aug 2009
    Hampshire
    Default Clutch + DMF + master + slave cylinder
    Hi folks,
    2006 1.9 CDTi 150... wife broke down this morning (in the car, not emotionally) with clutch pedal essentially all the way to the floor and not able to get it in gear.
    Car's been recovered to a local independent. Master cylinder needs replacing, as does concentric slave. Box is making a horrible noise at idle (to be fair it's been rattling for 18 months+) ... and so DMF is needed too.
    So... my question is - does this add up to:
    - New clutch
    - DMF
    - Master
    - Slave
    ... or is the "slave" part of the clutch? I'm just trying to assess how much I should be paying for this, referencing threads such as: http://www.vectra-c.com/forum/showth...3-noisy-clutch
    The car's done 110k miles and we've had her from 13k with only a Power Steering pump before now, so I can't complain. But it's still not the best day I've had in a while(!)
    Thanks all.
    Regular Member John Bishop's Avatar
    Oct 2010
    Had all 3 done a few months back. 3.0 V6 and had to hunt around but got parts and fitted for £850. Yours should be cheaper than that but DO NOT go through a Vauxhall Dealer. They will seriously rip you off. They wanted£1100 for the parts and another £500 to fit!!
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    http://www.ebay.co.uk/itm/2710955541...84.m1438.l2649
    This will replace it for ya. i just bought and fit this myself with help from a haynes manual
    hope it helps
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    ^^ Wish it were that cheap for my GSi. The cheapest I can find just a DMF for is £440 on eBay... Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Aug 2009
    Hampshire
    Quote Originally Posted by John Bishop View Post
    Thanks for the info.
    I wasn't really in much of a position to barter as the car was 45 miles from where I live, 55 from where I work, and undriveable. A local indy recovered it and quoted:
    Clutch - 144 + VAT
    DMF (LUK) - 192.50 + VAT
    Slave - 72 + VAT
    Master - 68 + VAT
    Labour (6hrs) - 390 + VAT
    ... totalling £1039ish ... but they agreed last night to do it for £1000. Not the cheapest job in the world but comes with a 2yr warranty and they're not charging for the recovery and diagnosis.
    She'd better run smoooooth after all this(!)
    N Ireland
    Paid 550 all in (i think) for parts online. The garage was making plenty from the labour to be stiffing you on the parts as well
    Aug 2009
    Hampshire
    Got the car back last night and it's a dream to drive... not quite as smooth as my C class... but a different animal compared to the vibrating chugger it was before. It's almost like 70,000 of the 110,000 miles its done have been taken away.
    Only one question... cruising up the motorway home, all was fine. However I came off the slip road, went to change gear and couldn't get it in. Clutch wasn't disengaging. I faffed at the lights for a bit before manually pulling the pedal back up with my foot, then depressing again. That fixed the issue. But it's done it again since then, needing the pedal to be pulled up before it works properly.
    I'll be taking it back to the garage next week to get them to look - but just wanted to check I'm not doing any major damage driving it like this until then.
    Thanks all.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Clutch pedal spring?
    Aug 2009
    Hampshire
    Apparently it just needs another bleed. Quite common on hydraulic clutches according to a mate of mine.
  1. Replace Clutch,Dmf & slave cylinder
    By pipamish in forum Engine & Drivetrain
    Last Post: 5th October 2012, 14:54
  2. Anyone had to have a clutch master cylinder?
    By DaveW555 in forum Engine & Drivetrain
    Last Post: 13th April 2012, 22:56
  3. cheap dmf , clutch and slave cylinder
    By samngeorge1985 in forum Engine & Drivetrain
    Last Post: 5th May 2011, 21:17
  4. Suspect clutch slave cylinder
    By kman247 in forum Engine & Drivetrain
    Last Post: 17th December 2009, 17:24
  5. Clutch Slave Cylinder on 2.0 DTI
    By cp123 in forum Engine & Drivetrain
    Last Post: 22nd December 2008, 21:45
