Thread: stereo surround
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default stereo surround
    not the usual question about what i need as the stereo is in and works a treat.
    what is annoying tho is the surround thing doesnt fit right and just sort of holds itself in with luck and friction but sometimes it comes off and its annoying me.
    how much do i need tocut off it to get it to sit right? or even better, would someone cut it down if i post it to them with a return envelope please?
    Jul 2011
    UK
    Year : 06
    Which surround mate is it the silver one shaped to the dash if so that goes thru the cage and locks in if it's the black bit around the CD player then all I've done os cut a couple mm off so it's flush and used bluetack to keep it in place so far it's been there a year and not moved also I used so double sided clear sticky things
    Sep 2011
    Birmingham
    Trim : sri
    both of them tbh, one clips into the other and then it doesnt clip into anything.
    maybe i should try putting the inner one in first then but iirc there maybe a lip in the way
    will try and get some pics later
    Jul 2011
    UK
    Year : 06
    If I remember the 1st surround silver one ya put the cage thru the surround and the lip on the cage stops the surround so when u push the cage in it locks the surround between the dash and cage then u use the black surround u got with the kit and it clips in
    Sep 2011
    Birmingham
    Trim : sri
    hhm, in that case mine might not be right then.
    the stereo is in place but the 2 frames are separate although clipped into each other.
    might need to look at it again then
    Sep 2011
    Birmingham
    Trim : sri
    oops, think i have gone wrong with mine then
    i have nicked this pic, hope ian doesnt mind
    think mine needs to come back out then, oops
    cheers marc and ian
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. Signum Stereo Surround
    By scooby8272 in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2010, 22:46
  3. stereo surround
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2008, 17:46
  4. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
