Results 1 to 10 of 13
Thread: help! 1.9cdti 150
    Oct 2012
    Cumbria
    Default help! 1.9cdti 150
    we have a 2007 1.9cdti 150 estate (82,000 miles) which is driving us mad! Hard to describe problem, the engine is lumpy (my husband says if it had plugs it feels as though 1 of them needs cleaning).
    we have looked on the forum and tried all the things below and we still have the same problem.
    checked swirl valves (now glued them open)
    Cleaned EGR and throttle body
    replaced 3rd injector wiring
    checked injectors
    used a de-coker
    my husband is about to give up and take it into our local garage, any further advice form anyone would be great.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    when you cleaned the throttle body did you resolder the joints or check them with a magnifying glass for cracks?
    Are there any lights on the dash?
    Have you had anyone check the codes if there is any?
    Have you replaced the fuel filter or when was the last time it was replaced?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could well be your DPF has got blocked.
    What mileage do you do?
    Oct 2012
    Cumbria
    thank you for a very speedy reply, I will check with my husband when he comes home from work.
    N Ireland
    I've done 8k since drilling holes through my DPF and it hasn't been lumpy since.
    Was on and off lumpy for 100k+ beforehand. Egr/boost sensor/thottlebody cleans/checks only went so far.
    It will liberate the engine
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check vacuum pipes too
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Check air box filter, check coolant, change fuel filter as my car's running smoother now the filter been changed,
    Get codes read. Cleared then take for a drive to get new current codes. Post them all on here :-)
    Oct 2012
    Cumbria
    Hi
    Sorry it has taken me so long to update on the outcome of the ongoing saga of my husbands car.Finally we have it sorted, it was the DMF, can't believe the difference in the car, runs brilliantly now. I have to say that this forum has been brilliant, we tried all the quick and cheap fixes that had been suggested before finally handing the car to our local garage. We purchased a new DMF ourselves and the garage fitted it, fingers crossed to trouble free motoring!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Good news, did you replace the clutch and release bearing at the same time a faulty DMF will have damaged the clutch?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Wherr in cumbria are u ??
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 1.9cdti sri 120
    By dsimpson15 in forum Introduce yourself.
    Last Post: 21st April 2012, 19:24
  3. 1.9CDTI 120 55 reg
    By rjw in forum Cars for sale
    Last Post: 15th March 2011, 15:28
  4. De-Cat 1.9CDTI
    By gregc in forum Diesel Engine related
    Last Post: 26th January 2009, 10:33
