Thread: keyboard advice
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default keyboard advice
    I'm after some advice, I want to get my son a keyboard for xmas, I want one were the keys light up to learn him to play and also usb so I can download midi files for it but can't find one with that's spec its either light up keys and no usb or other way round, has anybody got one or know anythink about keyboards
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    182 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    I've played a bit with Keyboards, MIDI, and computer connections.
    Unsure of your budget, unless you are looking at top spec professional gear then I think you can forget USB on the keyboard itself, just look for one with standard MIDI interface connections (5 pin round DIN Plugs in and out), the USB option will probably wind up coming from the PC you connect it to once you have found a suitable PC MIDI Interface kit (to plug into one of the PC's USB connections).
    Hope that helps, but unless anyone else wants to add something, a decent high street music specialist would usually be pretty helpful and give you some choices based on the options you are looking for.
    Essentially though, try to plan on letting your computer provide most of the extra MIDI functions via what can be a fairly cheap computer MIDI USB interface, just need to make sure that the keyboard has MIDI in and out, and that you have a suitable PC Music program to do the extra stuff (CuBase or the likes).
    Great fun by the way
    Sodding Typical on Sea
    I play, but the old fashioned way with midi connections and Yamaha gear. I would suggest a long talk with the people in a good quality Music shop there are fewer and fewer around but the ones that are there offer good solid advice.
    If you are serious and your child is too, then I would suggest that you invest in an 88key full size keyboard, worry less about the sounds and the toys as these can be added to via midi interface from a pc later, as it is down to the quality of the keyboard the rebound and the feel.
    Oct 2009
    Sandwell
    I used to play when I was a kid and want to get back into it, only want to spend about 200, I've seen a decent music shop when on the way to work yesterday ill pop into there tomorrow, was looking at the yamaha EZ220
  1. Wireless keyboard mouse
    By Wolflinn in forum General Chat
    Last Post: 7th December 2011, 22:07
  2. Samsung laptop keyboard
    By rob warrington in forum The 'Off Topic' room
    Last Post: 23rd November 2011, 22:23
  3. Could all of those not apt to using a keyboard...
    By John LE in forum The 'Off Topic' room
    Last Post: 27th September 2010, 21:17
  4. Laptop Keyboard
    By leeds vectra in forum General Chat
    Last Post: 26th February 2009, 01:17
  5. New DELL Keyboard
    By spoons in forum Comedy & Humour
    Last Post: 23rd May 2006, 19:28
