Thread: Spraying Advice
    Apr 2012
    Sheffield
    Default Spraying Advice
    Just in the process of colour coding the chrome V using rattle cans, I'm primed and ready for colour so I have a few questions to ensure I get the best finish...
    Should I wet sand inbetween each coat of colour or just the final one before lacquer?
    Do I polish up after sanding before applying the lacquer or after?
    Finally do I wet sand the lacquer then polish up to finish?
    Advice appreciated
    Regular Member mattbrad30's Avatar
    Jul 2011
    West Midlands
    Hi mate what i done was sprayed the colour left it to dry done another coat then left i then got the laq done at least 4 to 5 coats leave to dry 24hrs then get 2000 wet an dry sand so its dull then cut it back i use 3m extra fine compound
    Jul 2011
    West Midlands
    Apr 2012
    Sheffield
    Ok cheers for that!
    So you didnt sand before applying lacquer?
    Jul 2011
    West Midlands
    no mate if you sand you will see it once you laq it
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    17 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 212,060
    The base coat with metallic paint dries with a rough texture. If you sand that, you lose the metallic quality of the paint. The lacquer fills in the texture and adheres to it, creating the smooth, shiny surface with the metallic texture inside it.
    Does that make sense? You then sand the final lacquer coat to a fine finish using wet and dry and then compound, as described.
    Lacquer should be painted before the paint basecoat has cured but after it has JUST dried. That way, the lacquer will adhere to the base coat. Leave it too long and the lacquer may not stick and you could get adhesion failure and the lacquer peeling.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Apr 2012
    Sheffield
    Thanks for the advice, the colour and lacquer is now on.
    In terms if sanding and compound, I only have 1200 wet and dry, is this too harsh for the lacquer? Compound wise I dont have a DA, I have some original t-cut and SRP will these do the job?
    Dont wanna sand it if i dont have sufficient compounds to bring back the shine!
    17 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 212,060
    1200-grit will not give you a fine enough finish. You can get 2000-grit or finer wet and dry paper on eBay for a few bob. I bought a pack of about 20 sheets of assorted grades (up to 2500-grit) - delivered - for something like a tenner. I bought Klingspor paper, a German brand. It holds up really well. As regards a compound, Halfords sell a rubbing compound for a few quid that seems to work well, in my experience. It comes in a yellow toothpaste-style tube. I hope this helps. Paul
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    1200 is a bit rough although I have used it before with a drop of washing up liquid in the pot of water. 2000 is more suitable really though. Forget the t-cut, the SRP will polish it ok although it may take a fair bit of effort (just from my experience).
    Apr 2012
    Sheffield
    Thanks again, bought some 2000 and halfords rubbing compound, on the can of lacquer it says to wait 2 weeks before using a rubbing compound, do I really have to wait 2 weeks now to finish it off!? I just wanna get it on the car haha!
  1. Spraying My Grill Advice
    By OllyT in forum Styling
    Last Post: 2nd October 2011, 21:36
  2. spraying splitters/skirts advice
    By Mads in forum Styling
    Last Post: 14th August 2011, 12:55
  3. Spraying advice needed please
    By Vid in forum Bodywork & Interior
    Last Post: 3rd June 2008, 19:54
  4. Really need spraying advice for Lip Spoiler
    By S14RRJ in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2008, 13:38
  5. Splitter Advice (spraying)
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2007, 00:24
