Thread: Vectra c 1.8 sri 2006 running very rough and eml on. Plz help
    wirral
    Default Vectra c 1.8 sri 2006 running very rough and eml on. Plz help
    Hi, i have a 2006 vectra c 1.8 sri and a few weeks ago i noticed a very slight uneven idle, that went within a few days and tbh i didnt really think too much of it.
    today i was driving home from work when suddenly the engine started running extremely rough and the engine light is perminenly on. i swiched it off and left for 10 mins and no change!
    it doesnt seem to idle roughly only running rough, if your easy on the accelerator its not as bad but if you rev it slightly it starts running really really bad.
    any help would be greatly apprechiated.
    sam
    Regular Member coldo's Avatar
    Scotland
    Can you read the codes on your car using somethign like opcom or the pedal test (check the how to section for the pedel test way).
    If a light came on then chances are its recorded a fault which will help point to the issue.
    wirral
    hi thanks for your reply, ive just done the pedal test now and it showed 3 codes
    0597
    0564
    0402
    cheers
    sam
    Scotland
    0597 - coolant thermostat valve circuit low voltage.
    0564 - cruise control fault (I think)
    0420 - cat system below threshold (I think)
    Someone will be allong shortly who will confirm these all to you. Chances are 0564 is unrelated. 0597 may be afecting the car and causing the issues with 0820. but that's all guess work from me Im afraid
    wirral
    hi thanks for your help, ive done a bit of research and im going to take the egr valve off and give it a good clean and see if that helps, hope to do it 1 night this week after work.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    just fixed my step mums 1.2 clio with the same simptoms, turned out to be the coil pack. mabe work checking, if so i would advise a new set of plugs while ure there.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by rozzer2006 View Post
    All owners of French cars using that engine should carry a spare coil pack in the boot
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    I dont think the Z18XER has an EGR Valve, on the off chance you have one of the last of the Z18XE in your MY06 the EGR had it deleted at the end of 2003.
    When you rev the car are you getting plenty of exhaust gases coming out the tail pipe?
    Quote Originally Posted by C-Owner View Post
    Not only French cars, My sister has an A4, she carrys spare ones too.
    wirral
    Hi mate, thanks for UR reply, went out and bought a new coil pack and new plugs before. When I took the plugs out I seen the problem straight away....there was a huge gap in the plugs, they where the originals! Put new plugs in and the old coil pack and it's running like a dream and really quite again. Can't believe the plugs caused that!
    Cheers for your help guys
    Scotland
    result bud....
    A set of plugs is much cheapness....!
  1. vectra 3.2 running rough after chaning cam cover gasket?
    By kelly1234 in forum Engine & Drivetrain
    Last Post: 25th August 2012, 06:45
  2. vectra gsi running rough misfires high idle
    By shaunft in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:03
  3. 2.2 vectra running a bit rough
    By tweenage in forum Engine & Drivetrain
    Last Post: 20th January 2012, 16:20
  4. Rough running with KaN air filter
    By Kcs in forum Engine & Drivetrain
    Last Post: 21st February 2007, 22:45
  5. 3.2 V6 Gsi Rough Running From Cold
    By TOON VECTRA V6 in forum Engine & Drivetrain
    Last Post: 13th December 2006, 22:20
vectra c 1.8 running rough
