Results 1 to 10 of 13
Thread: Advice please on various Fault codes. Thank you
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Advice please on various Fault codes. Thank you
    Sorry Mods/Admins if this is not the correct section to post in.
    Been having a few issues with my vec of late.
    2006 1.8vvt Sri Nav with 93.5K
    When using the cruise control (which works fine) I now can predict that I get two errors shortly after.
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    Im also getting this unknown error
    P0597 - <Unknown DTC>
    (61) - Not present
    Over the last few days I have been getting this fault code too.
    P0621 - Generator Lamp "L" Control Circuit Malfunction
    (03) - Not present
    The only known problems on my car at the moment is that the Thermostat needs replacing.
    The car is running fine despite the above, but for how long I wonder.
    I am also getting an error with the power steering. Even though the pump is noisey it works fine at the moment. Not checked the fluid level yet.
    Could have sworn I saved the code on my lappy but can't seem to find it at the moment.
    Any ideas boys and girls would be much appreciated.
    Many thanks
    Chris
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    sorry cant help Chris , what i know about mechanics you can write on a stamp and still have room , , but im sure dean or one off the others will be able to help . good luck
    the vectra has gone , but not far away so ill still see it form time to time
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by happypostie View Post
    Thanks Khalid. You have helped me no end already so I will excuse you this time
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Test the charge from your alternator would be the first thing id check going by that last code.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for that mate.
    Could I ask how would I go about that the best way. Multi Meter across the terminals ?
    Aug 2012
    Yes should be around 14 to 14.5 if good I believe
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do they clear and come back again. Just with them saying not present usually means that the fault has passed for that ignition cycle.
    Might be worth following how to to clean switch contacts.
    Aug 2012
    Quote Originally Posted by Critch View Post
    That's interesting. I never knew that!
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi critch
    They all come back after a few days when cleared. I take it its a how to for the switch cleaning . Will have a look.
    Many thanks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    http://www.vectra-c.com/forum/showth...it+Malfunction
  1. Fault Codes
    Last Post: 28th April 2012, 19:02
  2. Fault Codes Help Please
    By paulhea in forum Vectra C / Signum Troubleshooting
    Last Post: 10th February 2012, 08:46
  3. Any advice with the following fault codes.
    By eaglepva in forum Vectra C / Signum Troubleshooting
    Last Post: 4th November 2011, 08:57
  4. Help with 2 fault codes Please
    By Luke1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2010, 17:42
  5. 2.2 DTi SRi fault codes advice
    By joyrider in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2009, 15:20
Thankyou fluat varions
p0621 vaushall 1.8
