Thread: Electric motor running sound when accelerating
    Jun 2009
    Middlesex
    Default Electric motor running sound when accelerating
    When i push the accelerator pedal down there seems to be a sound of an electric running starting a second later and finishing.a second.later after pedal is released.Any ideas?
    Carnoustie
    can you record it with phone?
    Ronnie
    Jun 2009
    Middlesex
    Engine is 2.2 Direct.Maybe more of a whining sound under bonnet that starts and stops as pedel is pushed.
    Aug 2012
    Could be a pulley bearing. Try removing the Aux belt - start the car (from cool / cold and only for a few mins) and see if the noise is gone (obviously you will get some other dash lights on for doing this). If it does then waddle each pulley to see if there is any play. If so then replace it. If not it could be a pulley on the timing belt. Failing that it may be a boost leak or intake leak. Usually though this would be more of a wooshing or whistling noise.
    I would start with the Aux Belt Pulleys.
  1. Strange blowing sound when accelerating
    By HooDLuM_X in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 21:57
  2. car running lumpy and now strange wooo sound when coming of boost??
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2012, 13:00
  3. boot motor running when release pressed.
    By stevegreg in forum Bodywork & Interior
    Last Post: 30th January 2009, 23:37
  4. electric sunroof motor and light panel
    By rorycarz in forum Parts for sale
    Last Post: 5th November 2008, 16:46
