Thread: What the hell???
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default What the hell???
    My wife went out to our car this morning to find a huge puddle of water in the passenger footwell!!
    Has this happened to anyone else? What has caused it to happen?
    I have a similar issue where the spare wheel is, it fills with water if it rains hard. There are some rubber caps around the wheel which I have punched holes into to drain it out.
    Help please!!!
    Carl
    Sent from my Samsung Galaxy SII using Forum Runner
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Have you checked the scuttle drain under the pollen filter could be blocked up
    Sep 2010
    water in the back,.. I understand the roof ariel rubber gasket perishes and then allows water to ingress and makes its way down to the boot well. Front passenger footwell as above,.. scuttle tray probably needs cleaning. Look in the how to section.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jamiedvvt View Post
    Personally I'd now remove the blower resistor in case it's wet. Then refit. Might save you £30
    ---Sent from my iPhone 4 using Forum Runner
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Remove the rubber bung in the scuttle panel so it cant happen again. And as chewy said the aerial rubber will be perished letting in the boot.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Check every weather trims, boot open, check its all in properly. Move rubber up and down to see still connected to clips.
    Check rear lights isnt leaking as it have weather trims on it too, check windows trims are ok.
    As for footwell, it'll be the scuttle area, there is 2 drain holes. One directly by the pollen filter. Via engine bay. If clear then check any issues with door weathering trim. Also check window is actually closed!
    Sponge it all out, then put newspapers down get summat not too heavy to compress it for a day should be ok afterwards. Let us know how u get on and what u find. Sometimes it helps others on ur results! :-) photo helps :-)
    STOCKPORT
    May 2011
    Thanks guys, it does seem that it was blocked. I have cleared it out, so hopefully won't happen again as I will now know to check it.
    As you can imagine it wasn't nice discovering that. Just have to let it dry out more.
    Carl
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Just throw the little rubber bit away mate, will take a few days drying out but at least it wont happen again
  1. Had my re-map done.....****** hell!!!
    By vectraguy35 in forum Diesel Engine related
    Last Post: 30th January 2011, 20:46
  2. ****** hell!!!
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 19:52
  3. What the hell !!!
    By spoons in forum General Chat
    Last Post: 13th January 2011, 19:48
  4. Bl**dy hell
    By copperdock in forum General Chat
    Last Post: 19th April 2008, 22:04
  5. Day from Hell
    By rob1964bike in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 01:16
