Results 1 to 3 of 3
Thread: CDTI 150 Estate Eibach Spring Part Numbers
    Nov 2011
    Swindon
    Default CDTI 150 Estate Eibach Spring Part Numbers
    I've seen a similar thread which seemed to cover the hatch models, but I appreciate the kit for the Estate cars is quite different.
    I've got an 08 1.9 16v CDTI SRI XP2 NAV Estate and am looking to replace my broken Vx springs with unbroken Eibach ones.
    It seems the two kits available are
    E10-65-011-01-22
    and
    E10-65-011-02-22
    From what I've read the first kit is for front axle weight up to 1060kg (or 1065kg, depending on where you read), and the second for front axle weight over 1060/1065.
    My car's ID plate shows a front axle weight of 1085kg, but I really don't want the front up in the air.
    Does anyone have pics/ details of...
    Which spring kit you fitted?
    What your listed front axle weight is?
    (Ideally with a good side on, crouching down pic to show how the car sits)
    Cheers in advance for anyone who'll help out - hopefully the keywords in the thread title will make it easier for anyone else looking in future
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    You can have a look on mine here, Z19DTH engine, automatic: http://www.vectra-c.com/forum/showth...74#post1902074
    -30mm Eibachs P/N: 10-65-011-02-22 (1130 Kg on the front axle).
    Nov 2011
    Swindon
    Just copying your pics in Lao:
    Quote Originally Posted by Lao View Post
    Attachment 63457
    Attachment 63458
  1. CDTI only Which Eibach spring kit did you fit
    By Thunder in forum Handling & Braking
    Last Post: 21st November 2013, 20:02
  2. Replies: 21
    Last Post: 4th November 2012, 22:31
  3. B12 Pro / B8+Eibach Part number confirmation for CDTI 150
    By muad_dib77 in forum Handling & Braking
    Last Post: 4th October 2012, 17:35
  4. 1.9 CDTI SRI Front Spring Part Numbers???
    By Warrenmole in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2009, 15:41
