Thread: Difficulty starting after EGR & boost sensor clean
    Sep 2012
    Ballymena NI
    Default Difficulty starting after EGR & boost sensor clean
    Hi guys, I drive a late 05 120bhp cdti vectra. I cleaned the egr & boost sensor on Saturday and the car ran like a dream, however after the car sat for a few hours she was difficult to start & idled roughly for a while.
    Then on Sunday she started & drove ok but again after letting her sit for a few hours she was difficult to start and idled roughly until she had had a few revs.
    I've used this site for years as a reference and would really appreciate your advice.
    thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check glow plug connections, coolant temperature sensor connection, and vac pipes. May have been knocked as you were working on it
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    What he said
    And check battery is running ok? Some things just started to show signs even if u done some work on it. Sometimes dont mean u done summat at all. Any codes throw up?
    Not been tinkling with the software?
    Sep 2012
    Ballymena NI
    Car was on code reader before & after I cleaned the egr & boost sensor and nothing was flagged up, I have recently replaced the coolant temp sensor and this is working correctly according to the code reader (and no I haven't been tinkling with the software).
    I will also advise you that although the heater etc works ok the car itself seems to run at an operating temp on 70-75 degrees which was why I originally replaced the coolant temp sensor.
    N Ireland
    My car was a ****** to start after i cleaned the egr, boost sensor and scraped a load of crud from the inlet manifold after taking off the butterfly valve to get access. But I havent had a problem since after I got it fired up. Wonder has some crud stuck in yours somewhere it shouldnt and its not clearing itself?
  1. Boost sensor clean
    By Ruffus2 in forum Engine & Drivetrain
    Last Post: 14th August 2012, 18:22
  2. Clean boost sensor?
    By mikeq in forum Engine & Drivetrain
    Last Post: 15th June 2011, 17:57
  3. Boost sensor clean!.
    By felixx in forum Engine & Drivetrain
    Last Post: 18th July 2010, 23:37
  4. Airbox Mod and Boost Sensor Clean
    By dolf.peeters in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 18:59
