Results 1 to 2 of 2
Thread: Rear Springs Replacement
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default Rear Springs Replacement
    Afternoon all
    Had a rear spring snap on me so i decided to tackle it today. Can i just say.... what a pain in the hole that was!!
    Just a bit of advice for anyone tackling it themselves, DON'T follow Haynes manual instructions when it tells you to use spring clamps.... cos there's nowhere for them to fit with all the suspension in the way!
    What i had to do instead was undo the bottom arm to hub bolt and drop the arm down to remove the spring. My thanks to gekornro for his How2, Saved me some time, and money for the swear jar
    3.5 hours to replace both rears, all done (2.5 hours spent ****ing about with the compressors, and it was ****** freezing!!)
    Lancashire
    i followed instructions off some of the posts on here and did not bother with spring compressors , i just went straight for the bottom bolt after putting my scissor jack under and lowered it down then used my foot to push the arm down and it just pulled out easy , i did both sides in about an hour and fifteen minutes
  1. Replacement springs question
    By Chip in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2012, 19:55
  2. replacement springs 1.9 cdti sri
    By sardean in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 00:19
  3. Need replacement springs for SRi 2.2DTi...
    By Innes in forum Handling & Braking
    Last Post: 7th February 2011, 16:53
  4. Replacement Springs Shorter?
    By yoclick in forum Handling & Braking
    Last Post: 8th January 2011, 17:18
  5. front springs replacement
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2007, 14:15
