Thread: cdti 120 cut out after thermostat change
    Oct 2012
    liverpool
    StatsVehicle Info
    Default cdti 120 cut out after thermostat change
    Alright guys got little problem here but unsure what to do. Just replaced thermostsat. What a nightmare but since done it the car won't start. Well it did start for like 10 mins then it just started struggling to idle an cut out. Power steering lcd came on to. Tried starting an no go. But I'm not sure if it coz I'm low on fuel. I parked on a kerb (passanger side) an since then cut out. I got 10 miles fuel left. Not sure if diesel low or a connector has water in. There's enough power to turn starter but no go
    StatsVehicle Info
    Does sound like its out of fuel.
    My fuel light comes on about 60 miles to go.
    Letting it get that low you could have sucked up crap in the tank and also risk running the pump dry and killing the pump.
    Oct 2009
    UK
    StatsVehicle Info
    Sounds fuel related. When I picked my current Vectra up, the range was on 1 mile. Drove 2 miles to the nearest garage, filled up, but the car was hesitant for a good 20 miles after filling up. A good thrashing sorted it
    East Midlands
    StatsVehicle Info
    Have you disturbed any fuel lines at all,sounds like you have air in the system,stick a gallon of juice in her get some easy start get a mate to turn engine over while you spray into air intake should start.
    Oct 2012
    liverpool
    StatsVehicle Info
    Thanks for replies. Parking car on kerb caused fuel starvation. Fresh fuel an primed a few times and could hear an air rush. Now running fine an steering rack fault was dodgy wire. Cheers guys
  1. thermostat change
    By marc vectra sri in forum Troubleshooting
    Last Post: 27th October 2012, 00:27
  2. Do i change my thermostat?
    By beggsy in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:59
  3. How2 for CDTI 120 thermostat change?
    By westonprawn in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 17:03
  4. CDTI 120 thermostat change
    Last Post: 14th January 2011, 19:33
  5. thermostat change cdti
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 9th January 2011, 23:57
