Thread: Clips holding pollen filter
    Regular Member marky2027's Avatar
    Northumberland
    Default Clips holding pollen filter
    At some point during a service somewhere one of those daft clips holding the pollen filter in place has been snapped off. I'm currently having trouble with the heater motor and resistor and when i've looked the filter is hanging forward by one corner where the clip has snapped. Has anyone got any solutions for holding the pollen filter in place??
    May 2006
    scotland
    Yes. Same happened to mine. Just take the filter out and before you re-fit it, pack under the paper flap with some foam (I used some from an old settee cushion). When you fit the filter back in, the foam should give it a tight enough fit to prevent it from falling forward. As well as foam, any soft material packing should do the same job e.g. a bit of soft wood, a bit of polystyrene etc. Mine is rock solid and has been for months. A paper clip may even work.
    Northumberland
    Good tip thanks mate. I've ordered a new filter as this one looks a bit grotty and will do this when it arrives
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I had the same problem and used an elastic band, some tie wraps may do the same job
    Northumberland
    Experimented with the old filter and found a paper clip to be excellent. Put it along the top/long edge beside where the broken clip is. I was concerned if it came off and got sucked into the fan motor so a small blob of super glue on the clip has sorted that. Ill just snip it off when i have to change the filter
  1. Broke one of the pollen filter clips
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 21:35
  2. Fuel filter holding
    By JKB89 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 14:37
  3. Pollen Filter retaining clips - rubbish quality
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 16:18
  4. Pollen Filter
    By Merick in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2007, 19:26
  5. Pollen Filter.....
    By nabs44 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2006, 08:51
vectra c pollen filter clips
