Thread: Z18XER (1.8VVT) Cam Pulley Noise
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Default Z18XER (1.8VVT) Cam Pulley Noise
    Hi Chaps,
    Just got back in after doing an engine clean with AG Engine cleaner....
    Fired it up, and christ on a cross trainer my Cam Pullies are ticking like mad! Took it for a spin to warm it up (20 mile run). Still there. It's very regular. and annoying. Just worried now. Not sure how the AG got in there. I was very careful with it.
    Any one else do this?
    How much are new ones/Cambelt Replacement?
    Matt
    Dec 2011
    Seaham
    Can you give them a squirt of WD40 to see if it quietens them down?
    Feb 2012
    Calne UK
    Quote Originally Posted by Ben50n View Post
    They are under the Cam Belt Cover. I don't understand how the AG stuff could have got there?
    I wonder if it's just a coincidence... but it's a HUGE one if it is. They where fine when I got back from Halfords.
    I know because I left the engine running whilst I decided how to use the AG Spray.
    Not sure why they would start making a racket now though. She's just had new oil and a Vx Filter too. (as per usual)
    Matt
    Full Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    6 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Sounds like the engine cleaner has got in and dissolved any lubricant that was in there,take the cover off and lube the tensioners[lightly] with some wd40 to start with and see how you get on,you might have to get some decent lube on later as wd40 will not last long-call into Halfrauds or somebody like that,if you don't do anything you may damage the bearings in your tensioner's----Dave
    Feb 2012
    Calne UK
    Quote Originally Posted by dave1419 View Post
    Thanks, I'll give it a bash tomorrow morning. Do you think lithium grease will be OK for a Lube for the bearings?
    Matt
  1. Z18XER (1.8VVT) Cam Solenoids
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 2nd February 2013, 10:35
  2. 1.8VVT (Z18XER) - How Long To Get Up To Temp?
    By puppet in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2012, 20:14
  3. 1.8vvt z18xer misfire
    By wozza in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 11:33
  4. z18xer 1.8vvt wigan area missfire
    By cerbrious in forum Engine & Drivetrain
    Last Post: 26th November 2009, 19:32
  5. Hydraulic Pulley on 1.8vvt Cambelt Question?
    By 67688c in forum Engine & Drivetrain
    Last Post: 31st August 2009, 17:21
z18xer vvt pulley
vauxhall vectra c 1.8 petrol cam vanos noisy
vectra 1.8vvt noisy cam belt pulley
vvt pulley
vectra cam pulley noise
vectra 1.8 can pulleys
vvt cams z18xer
z18xer noisy
noizy cam pulleys z18xer vvt
