Thread: Does this turbo sound normal? Video inside.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Does this turbo sound normal? Video inside.
    Took a short video of me revving my engine, does it sound like there is a split hose somewhere or are they supposed to whistle and hiss this much?
    Thanks.
    http://www.youtube.com/watch?v=phT6UEyaTQ0
    Regular Member franko's Avatar
    Aug 2012
    goole
    hi mate watched ur vid sounds normal enough to me ive got a 1.9 cdti and it sound the same as yours it pulls like a train
    Jul 2011
    UK
    Year : 06
    U have ur self a boost leak mate way too much hissing my 150 just makes a nice turbo spool whistle check ur intercooler hose big thick one next to battery and the vacuum hoses
    Mar 2011
    Wirral
    Hi mark, video doesn't do the sound much justice it is actually a bit louder and more prominent than the video shows. I've checked all hoses in sight with no luck, when I get someone else to rev it, the whistling and hissing sounds like it's coming from infront of the air filter box, is this a usual area for a boost leak? I did remove and check the one that comes off the top of the battery box but it was fine :/
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by john506 View Post
    Ah yes it does sound like air filter is there even one in there that's what it sounds like
    Mar 2011
    Wirral
    Yes there is an air filter in there, there is one screw on the air filter box that just spins, surely not this?
    I have also done the air filter box mod were you take the cone piece out, anyone else experienced hissing after this?
    Still does pull well, in 2nd gear the car jumps from 15mp to 40mph so plenty of umphhh!
    Jul 2011
    UK
    Year : 06
    No idea then mate I've taken out the bottom piece and shortened the intake and it don't sound like that
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Its a normal sound on 1.9 cdti. When you have load on engine and turbo boost hard the sound dissappear.
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by zafira View Post
    Mine don't sound like that mines nice and quite with just a whistle from turbo
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Don't just check the hoses if they are broken, also check the metal clips that help keep the hoses in place. I had a similar problem and it turned out to be a worn metal clip (I don't know the exact term of it) that held the hose from the intercooler to the inlet.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Does this sound normal (Video Z20NET)
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 11th December 2011, 14:05
  3. Noisy inside cabin - Sound proofing
    By hotrod09 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 21:52
  4. Whining sound from cambelt?? Desperate..please see video
    By claudiu666 in forum Engine & Drivetrain
    Last Post: 25th June 2011, 11:32
  5. turbo whooshing noise (not normal)
    By robshortman in forum Engine & Drivetrain
    Last Post: 24th April 2010, 13:17
