Thread: Timing Belt Failure
    Stratford upon Avon
    Default Timing Belt Failure
    Hi,
    My timing belt has failed on a 2004 1.9 CDTI(120).
    I just wondered if anyone knows whether these engines damage valves when the belt goes?
    James
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by higgy1541 View Post
    Hi,
    James
    they normally damage a lot more than just valves
    Stratford upon Avon
    What else do they damage?
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    You need to take the head of to check, my 150 failed at high speed on the motorway, two garages said it would be toast... 6 new rockers and a belt later all is fine, the rockers are about £8+ each tho...
    Edwinstowe
    Trim : VXR-D
    on the Alfa's (same engine ) we have had snapped cams and broken buckets and even head damage , only way to find out the damage is start stripping
    Stratford upon Avon
    Just thought i'd ask before I started stripping.
    Ive not long finished replacing the front sub frame, all 3 radiators, the front bumper and front n/s wing after an accident.
    Guess its going to be off the road for a while longer.
    Cheers guys
    Engine : 1.9 CDTi
    After doing a good 30 of these now I have not come across any that have done valve damage.
    They are designed to break rockers.
    Take the cam cover off and replace the damaged rockers (Never had to take a head off)
    Edwinstowe
    Trim : VXR-D
    Quote Originally Posted by leemarksmith View Post
    Quote Originally Posted by lee gsi View Post
    its a 120bhp not the 16v 150 bhp
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The 120 will usually do a lot more damage than the 150 when a timing belt snaps.
    Engine : 1.9 CDTi
    Ah didnt notice the 120 bit.
    Scrap everything I said lol
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt failure/knackered engine???
    By 123rado in forum Engine & Drivetrain
    Last Post: 15th December 2012, 18:35
  3. Timing belt
    By don1966 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2012, 18:55
  4. Timing Belt?
    By Rab in forum Diesel Engine related
    Last Post: 5th May 2011, 20:14
  5. Timing Belt Kit
    By theo in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 18:40
