Results 1 to 10 of 20
Thread: 12v permanent feed in boot needed
    ijk571
    Guest
    Default 12v permanent feed in boot needed
    Teaches me not read the description properly. Have just done the socket in boot mod, using the HOW2. Was testing it, and saw it was ignition switched!! When I re-read it I saw that's what the HOW2 was for.....
    I wanted a permanent live feed. Luckly I hadn't drilled any holes yet.
    I Have used Fuse No. 17 and a piggy back blade holder.
    It's not what I want as I want to attach either a battery conditioner via the socket or a solar powered battery charger/maintainer.
    I know there is a feed above the 40AMP fuse (and below it). Are there any fuses in the rear fuse box that are permanently live? I'd like to re use the piggy back blade holder if possible?
    Last edited by ijk571; 3rd November 2012 at 17:35. Reason: makes more sense now...
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    I fitted a 12v Aux in my boot and wired it up using the how2, mine is 12v all the time.
    ijk571
    Guest
    Could that be because yours is preface and not full canbus?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Possibly. Surely not another cost cutting measure, lol.
    ijk571
    Guest
    Also, if I do have to use the feed above the 40 amp fuse (if I can't use the fuse board) I assume I can use safely use a 15amp fuse in the inline fuseholder? I am a bit of numpty when it come to in car electrics..
    ijk571
    Guest
    Any ideas? I would like to get this sorted today if possible, thanks
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The big ones at the top are all constant live.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes you can use a 15amp fuse as it only affects the cable that comes from it
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    These are constant live's. Obviously one side is + and the other is -. You'll need one male spade connector and just push it straight into the empty port, then just put an inline fuse holder in and bobs your uncle.
  1. Permanent live in boot
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 20:11
  2. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  3. Permanent supply in boot?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 15:06
  4. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
  5. Where can i take a permanent live feed from rear fuse box ?
    By deanos in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2009, 16:40
