Results 1 to 10 of 23
Thread: Blower not working on position 1....resistor?.. where to buy from?
    Regular Member marky2027's Avatar
    Northumberland
    Default Blower not working on position 1....resistor?.. where to buy from?
    The blower on my facelift vectra c 56 plate has been dodgy for about a year now. Has been playing up and sometimes not working on 2 and then 3 and so on. Now I've got nothing on position 1 at all. 2,3 and 4 work fine. From researching on here it seems it is the resistor.
    I've read the how 2 and it seems pretty straight forward to replace. I'm not going to try and repair my old one and would rather just replace it.
    I've seen loads on ebay http://www.ebay.co.uk/itm/Heater-Mot...ad9bad4&_uhb=1
    I think the VX part number is 9180020 but has anyone used these cheaper ones? What are they like and should I look elsewhere?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine stopped working on Speed 1. New eBay resistor sorted it
    The one in your link is the same one I got
    Northumberland
    Reet....better get back on fleabay and order it
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Reach through pollen filter housing and give fan a spin. My motor had been repeatedly filling with water and the increased load to spin it had caused mine to fail. I'm glad I read more threads on here about removing scuttle tray bung and removing and lubing motor.
    Northumberland
    The little nut on the top was corroded so it seems that water has got in at some point. It does spin by hand and there is some light resistance but it's hard to know if this is normal. should there be any resistance?
    Northumberland
    I've just stumbled on a thread that involved dropping a little oil onto the centre of the fan whilst reaching in from the pollen filter housing. Might try this tomorrow
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    When I spun mine it was quite stiff. After WD40 and oiling it ran on a little after releasing, there will be some resistance due to the brushes on the motor.
    It's about an hours work to remove the fan and reinstall, awkward though I reckon only a two spanner job on the Haynes difficulty scale.
    Northumberland
    Going to try oiling from the top first and see if it makes a difference and going to order the resistor.
    Northumberland
    My advice to you all is DO NOT BUY A CHEAP RESISTOR off ebay. Mine arrived damaged and my mate had to re-solder the joint. I had to cut some of the plastic away as the cut outs were on the wrong side. Once fitted the fan was even spinning when it was set to 0. Ehhhhhhh?? And then....strong smell of burning......resolution......part in bin......trip to dealers.....£34 VX part. Works a treat. Money refunded from ebay seller. Job done
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I got a resister and my car dont have one! So its availible, i'll post it in for sale section. Good quality semi expensive one. Paid £37 for it! Dont know why me car dont have one!
  1. Blower Motor Resistor
    By VectraMikey in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2012, 09:23
  2. Blower Resistor pack
    By jammy_c in forum Bodywork & Interior
    Last Post: 16th October 2012, 20:00
  3. Heater blower resistor location ?
    By poves in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:05
  4. blower resistor
    By bigbenny4gf in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 19:29
