Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Zafira B coolant temp sensor
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default Zafira B coolant temp sensor
    Does any one have any knowledge of the zafira b 1.8 engine trying to find where the coolant temp sensor is located on the car as these stupid cars have to temp gauge and the fan ain't kicking in and it overheats. Grrrrrr lol
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Should be on the thermostat housing. Follow the top hose to the engine.
    Edit: Sorry Zafira B, so should be the Z18XER, vvt engine. So if same as the Vec C VVt its on the right hand side of the Cylinder head, just above the gear box.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Heres a z18XER, ive circled the thermostat housing.
    Are you VXR Enough
    13 Post(s)
    Great pic fella but don't see the temp sensor I just brought one from euro and doesn't look like anything on the thermostat housing
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Is the picture the same as your engine? The temp sender has a black multi plug connector IIRC.
    Here is a thermostat housing for a 1.8 vvt, the black bit is the temp sender unit.
    http://www.ebay.co.uk/itm/Thermostat...item416d7b89c8
    Are you VXR Enough
    13 Post(s)
    Yes bud that's the engine and the sensor I bought from euros has a nut under the plug and I can't see anything similar on the thermostat bousing
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Did they sell you one like this?
    http://www.ebay.co.uk/itm/Opel-Vectr...item43b4f9655f
    If so they've sold you the wrong one. TBH Im not sure if the CTS is available separately for the VVt. Have you checked the fuses are ok? If you pull the multiplug off the thermostat housing I am pretty sure the fan should kick in. It does on Vec's, imagine it will on the Zaf.
    Are you VXR Enough
    13 Post(s)
    Right they did sell me the one you put a link up off so I'm not going mad cos I thought I couldn't see anything like it on the car lol.. These zafira's are just stupid having no temp gauge what were Vauxhall thinking!!! Basically what's happening is the fan doesn't kick in when the car gets hot now I've used my diagnostic software we are not allowed to mention lol and tested the fans and they both work and then watched the water temp climb on the pc it hits about 104 and starts bubbling and then over heats no sign of fans cutting in so mu question is would the cts cause the fans not to cut in or am I barking up the wrong tree lol
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    They have sold you one for the z18xe, not the z18xer, tbh Im sure you cant get a cts for the 1.8vvt on its own. All I can think of is the cts is knackered, and most likely you will need to change the whole thermostat unit. In the meantime if the temp starts to climb, whack the heater on hot and the fan on full and open a window, should help prevent it over heating mate.
    Jun 2011
    wolverhampton
    Unplug the plug on the thermostat housing and see if fans run with engine on? If they do the wiring is ok it's ya sensor. If not check the wiring
  1. coolant temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2012, 23:18
  2. Coolant temp sensor
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 11:54
  3. coolant temp sensor
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 22:27
  4. coolant temp sensor help
    By mrdouglas in forum Vectra C / Signum Troubleshooting
    Last Post: 12th March 2011, 21:01
  5. coolant temp sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 15th September 2009, 02:27
zafira coolant temp sensor location
zafira b engine coolant sensor
where is temp sensor on a zafira b 1.6
zafira b engine temp sensor
zafira radiator temperature sensor
vauxhall zafira engine coolant temperature sensor location
vauxhall zafira 2005 coolant temp sensor
vauxhall zafira b 1.8 engine management temp switch
vauxhall zafira temperature sensor location
vaxaul zafira change temputure sensor
vauxhall zafira thermostat sensor
vauxhall zafira coolant temperature sensor location
zafira b 2009 coolant sensor
how to on plug heat sensor on vauxhall zafira
temperatur senzor opel zx18xer
zafira b change coolant sensor
zafira correct coolant temp
zafira btemperature sensor location
zafira b coolant sensor
location of temperature switch in opel zafira 1.8
vauxhall zafira thermostat problems
Ect sensor zafira
vauxhall zafira b coolant temperature sensor location
vauxhall zafira 1.6 temperature sensor problems
location of temp sender on diesel zafira
