Thread: What size resistor?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default What size resistor?
    What size resistor will i need to cancel the error on my High beam bulbs. I've replaced standard bulbs with a 5w Cree LED. I've got a circuit that stops the pulse but i need to put a resistor in parallel to stop the bulb check message. Ta.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    i would say it has to be the same as the bulb that came out, if its the highbeam as u say i think they are 55/60watt?? get one to suit of ebay.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    one way is to meter the resistance of a standard bulb to get the resistance you require then get some from Maplins or RS
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    How have you done this Wilko? I fancy H7 led high beams as there only used to flash...
  1. LED Strobing & Resistor Size?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 21:26
  2. vec c resistor fix
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 22:00
  3. Resistor
    By dave_scarborough in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 19:17
  4. Resistor
    By philmorris in forum Vectra C / Signum Troubleshooting
    Last Post: 15th December 2008, 12:34
