Thread: Ncdc 2013 radio safe
    crook
    Default Ncdc 2013 radio safe
    Fitted ncdc paired head unit and screen from another car and radio safe keeps coming up ?
    doesnt ask for code,tried keeping AS in but nowt
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Needs to be coded via Tech2.. and looks like its paird allright.. but not to eachothe..
    crook
    Will op com not do it ?
    Engine : 2.2 Direct
    Maby.. i havent put in the wire from the NCDC to the Diag port on mine..
    milton keynes
    are you sure there wasnt the telecom kit aswell previously? it sounds like that may be the issue as even though the ncdc goes in a half canbus car , they are all paired to each other
    crook
    Car it came out had no telecom kit according to seller.
    think I need security code from car it came out, because on opcom it cannot communicate with head unit ?
    unit turns on ok.... Until tuner button is pressed or any button really...
    Also steering wheel buttons don't work
    Engine : 2.2 Direct
    When no communication with HU you need to run the wire to pin12 of the diag-port.
    crook
    Which wire ?
    mine had ncdc fitted as standard
    Engine : 2.2 Direct
    didnt you also have a tech2.. its a wire from back of radio to diag-port pin 12.. cant remember what pin on the back of radio.
    crook
    No I haven't had or got tech 2
    On display on opcom after picking ncdc2013 heading, only think that comes up is activate and de active head unit but need security code which I never got with head unit,
    Would 1 of the Internet company's give me security code for head unit... Dealers would be arm and a leg
  1. Replacing A NCDC 2013 Radio with a 'Normal' double DIN Headunit?
    By StreetDragster in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2013, 21:41
  2. NCDC 2015 display safe
    By stewartg1 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 09:34
  3. ncdc 2013 radio safe
    By thecarlotz in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 11:58
  4. Ncdc 2013....safe mode
    By bigcarman79 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2009, 20:44
  5. NCDC 2013 CDC Safe
    By pulseracing in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2008, 19:23
