Thread: Slow power when under 2000,
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Slow power when under 2000,
    As above. Since i changed fuel filter the old one sodden black, replaced with new white filter in. Filled it up with fuel before securing the screw cap and fitted. Started after a few turning, no issues, no fuel leak. Done job well. This was yesterday.. Took car for a drive today feels a bit off power is weak under 2k til it reach 2000 turbo kicking in and opphhhhh as it should.
    Coolant issue as its leaking out of the system somewhere! Car booked in monday for a closer inspection from well known and good reputation garage which means my bank balance will be down faster! As people say. Expensive means best job done than cheap and problems
    Is there any links?
    I know egr valve is fine, booster sensor is spot on, i know there is a split in intercooler hose but good for the oopphhhhh really but under 2000 revs? Like its a slug. Might be cos its cold out??
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Cold air gives more power as it is denser and therefore more air can be squeezed in and more fuel bigger bang and all that jazz. After all that's why we have inter coolers.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The split in the intercooler house is the problem because its not meant to be there!
    Its lettting the power out and it would be a good idea to replace it
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I will replace but cant find the hole. But why it feel like not much power when i put foot down under 2000? Slowly build power til 2000 revs when turbo kick in. Cant be fuel filter causing that can it? Or need more miles for it to be properly absorbed and flowing better? Or am i missing something else? The boost hoses are holding til i go 60mph or over heavy footed but manages ok sensible footed!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by paulhb View Post
    What i thought but running cold in cold weather not good right?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you have a hole in the intercooler thats your problem
    Jun 2011
    wolverhampton
    It's the hole in ya pipe as you are getting wrong fuel air ratio. 100% ya issue
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I gathered that but was fine before i replaced fuel filter. Could it be a crap filter? Paid £6 for it!
    Jun 2011
    wolverhampton
    Hose is gone so try that as you Gota have it regardless anyway
  1. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  2. No power under 2000 rpm
    By Munch85 in forum Engine & Drivetrain
    Last Post: 2nd June 2011, 09:50
  3. Exhaust emission light and loss of power below 2000 revs
    By craigb in forum Engine & Drivetrain
    Last Post: 14th March 2011, 15:08
  4. Lack of power und 2000 rpm ??
    By nigec in forum Engine & Drivetrain
    Last Post: 21st March 2010, 19:50
  5. Signum 1.9CDTI Low power under 2000 RPM
    By CowFish in forum Engine & Drivetrain
    Last Post: 2nd February 2010, 16:45
