Results 1 to 10 of 14
Thread: If it aint broke, dont fix it
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Default If it aint broke, dont fix it
    This is so true, i wish i hadn't bothered to try and clean the EGR on my 2.2 dti. I had a holiday today and i thought, i know i'll clean the egr up. Now to say that little sod was in tight is an understatement. Loads of wd40 and loads of little gentle taps around the housing it just wasn't shifting, hours i spent on it and eventually came to the conclusion it wasn't shifting, but me being me i thought NO it's not getting the better of me, an hour or two later it started to move. Excellent i thought until i noticed i had somehow cracked the little brass pipe comming out the top of the egr. So iv'e spent the rest of today soldering it back up. I checked Ebay to find out how much for a replacement. Great i thought when i seen the CDTI's comming in at around £60-80 but no no the Efin DTi is around £300.
    Really scunered now, 1 step forward 10 back. I'm not sure how much longer my poor old dti will be with us.
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    My pipe split too on my cdti,115 quid with the VAT
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    linky
    VAUXHALL EGR VALVE - 93176989N
    Vauxhall Spare Parts | PART NUMBERS | 93000000 - 93999999 | VAUXHALL EGR VALVE - 93176989N
    Vauxhall Egr Valve
    Part Number: 93176989N
    Price: £249.50 (Including VAT at 20%)
    Quantity:
    This is a new Vauxhall Part. VAUXHALL EGR VALVE. Fits
    Vauxhall Vectra 2002 - 2008 with Y20DTH , Y22DTR engines
    Vauxhall Signum with Y20DTH , Y22DTR engines
    Vauxhall Astra 1998 - 2004 with Y20DTH engine
    Vauxhall Zafira 1998 - 2005 with Y20DTH engine
    Vauxhall Frontera 1999 - 2004 with X22DTH , Y22DTH engines
    As this is a high value part it will be despatched via a Courier Service. It will require a delivery signature.
    Your Basket:
    View Basket
    Checkout
    Items: 0
    Value: 0
    Featured Parts
    Vauxhall Camshaft Sensor
    £45.52
    find out more
    © Vauxhall Car Parts 2013
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    i would be at the scrappy for one.
    Engine : 2.0DTi
    Mileage : 73350
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    cheers for the links guy's much appreciated, i'll wait and see how my repair holds out but i could try one of the local garages if need be too, i get 10% of with a club i'm in, it all helps.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    if all else fails then bypass the water pipes to the EGR , at least it will get you away .
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Quote Originally Posted by DTi Elite View Post
    Good point. Iv'e heard about doing away with the egr alltogether before but iv'e not researched this option yet. I don't know if thats even possible on the dti, i could easy make a blanking plate and connect the water pipes but what would you do with the electrical side of things, i presume it would throw up a fault ie the spanner light. would she run better without the egr?
    May 2012
    county durham
    Mileage : 145k
    leave the egr in place , plugged in & working but connect the water pipes to each other instead of to the valve .
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Okay :-) i'll keep a check on my repair and if it weeps i'll by pass the pipes.
    cheers
  1. tell me this aint right
    By bobbleheadbarney in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2012, 01:30
  2. Do you live by the phrase "If its not broke dont fix it"
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 23:22
  3. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
  4. Fuji GP Warning spoiler, dont look if you dont want to know!
    By rushy in forum Motorsport / Formula 1 etc. chat
    Last Post: 12th October 2008, 13:23
  5. They aint all bad!!!
    By mshaw in forum General Chat
    Last Post: 10th October 2007, 17:58
vectra 2.0 dti egr valve snapped brass pipe
