Results 1 to 10 of 29
Thread: oil light
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default oil light
    After changing the oil and filter yesterday i have now noticed the oil light takes about 5 seconds to go off from cold or being stood a while i used 5/30 fully synthetic, never noticed it before i changed to oil is this something to worry about or just me being paranoid no weird noises or that and oil level is fine checked twice to make sure 1.8 vvt engine
    11 Post(s)
    Did you use a genuine oil filter?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The filter could be emptying while the engine is off, meaning it will take about 5 seconds to re-fill once you start the car, hence the delay in the light going out
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    No was one from euro i got was going to change it next week as the old oil filter was in bits when i removed the cover will it be okay to use til next week without causing problems ?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    The vvt has a paper element filter so the oil all drains back anyway. It is possible that because the filter had collapsed that it was keeping the filter housing full of oil. A few vvt owners have noticed it take a few seconds for the oil light to go out. One thing I would say is do not be tempted to rev the engine while the light is on.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Quote Originally Posted by jamiedvvt View Post
    Same thing happens on mine... I guess it always happened, just I noticed it the first time I did an oil and filter change. I use genuine filters and the same thing happens. It just drains out of the system over night.
    I use Magnatec to try and help first start engine wear...
    Matt
    Dec 2011
    Seaham
    Mine is the same, takes a few seconds for the oil light to go out, it could actually be due to a sticky oil pressure switch??
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Well not to worried about it now then as a few others do it, thanks guys i thought something was wrong with the car
    Dec 2011
    Seaham
    I admit I was concerned about it as I also had trouble with the VVT Cam Phaser solenoids. I flushed the engine, new oil and filter and it has not made any difference to the time the light goes out.
    The filter will drain as there does not appear to be any anti-return valve.
    Best advice is to start it normally and let the light go out before revving the engine.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    yeah i always do mate thanks for the advice i don't normally drive anywhere for a few mins as need to demist the windows which is the biggest problem with my car lol
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
