Thread: Interior bulb.
    Regular Member Kenny_Exclusiv's Avatar
    Feb 2011
    Glasgow
    Default Interior bulb.
    Anyone confirm the fitment for the map light bulbs in the front of the car? and how many bulbs i need, 3?
    Want nice white bulbs instead of the yellowish ones.
    And what about the rear lights? they the same? easy to change?
    May 2011
    luton
    Yh mate preety simply to change youl need the same ones for your side light or look for festoon ones
    Jul 2011
    UK
    Year : 06
    W10 wedge bulbs 2 map lights and 2 main 2 rear
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    If you want nice bright white ones, might be worth while getting LEDs. A lot of members have been using em & they're bright as heck!
    Feb 2011
    Glasgow
    cheers guys! much appreciated
    So i can get some LED w10 bulbs then? 6 in total?
    Looking at the festoon ones, what size? 32mm/42mm etc? lol
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I bought canbus safe ones here
    http://www.ebay.co.uk/itm/130591243207
    They work OK in the front, but I had trouble getting them to work at all in the rear seat light, so I have got Mtec501 bulbs in the rear.
    Not sure what the problem is/was, but fronts would'nt work either with LED's in the back.
    To get the old bulbs out some 1/4 inch internal diameter clear plastic tubing (as on vacuum gauges, etc) can be slipped over the bulbs and used to pull them out.
    Plus LED bulbs only work when inserted the correct way around, ie, if it does not work remove it and turn it around.
    Hanging Heaton / Batley
    20 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Tony, Try taping up or scratching off 2 of the contacts, so one of the + and one of the -, just make sure there not on the same side...
    No idea why but instead of it just not getting the polarity the right way and not lighting it seems to cause a short circuit, I had issues on a set of standard LEDs that had wrap around contacts, I just trimmed them... Hope this makes sense...
    Oh and Kenny the 20smd ones seem to be brightest I've used, I put a thread up somewhere of the ones I have now...
  1. Vectra 1.8 SRI interior bulb (red)
    By Jakechapple in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2013, 23:51
  2. Front Interior Bulb
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2012, 23:34
  3. rear interior light bulb change
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 10:25
  4. Interior Bulb Q??
    By OPC in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2010, 20:20
