Results 1 to 10 of 23
Thread: power steering and traction control lights on
    Sep 2011
    Kent
    Default power steering and traction control lights on
    Car is 54 the y30dt drives normally no issues at all steering still ok etc
    But the traction control light on all the time and power steering light on most of time but does flash on and off
    Any ideas ?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you need to get the codes read fella
    Sounds like CIM failure to me
    Are the lights on all the time or did it occur once and it has been fine since?
    Next time it happens, turn one of the indicators on then off
    If the light stays on, then it is CIM failure
    If not, try the other direction just to make sure
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Power steering light I believe is a communication error somewhere but I don't know where exactly. Fault codes need to be read though.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Im with m8internet suspected steering angle sensor failure in CIM unit , hence tc and steering light on... Get codes read but sounds like new CIM to me
    Regular Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    might not be cim could be anything fella you need to get the codes read before anything else
    Sep 2011
    Kent
    I'll get codes read the indicators do cancel ok etc. It's more annoying than anything
    Quote Originally Posted by GazCDTI150 View Post
    You don't get reliable fault codes with CIM failure, until it has failed completely
    I had to wait three months for mine to become permanent
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    M8internet he needs to get the fault codes read. Lets be honest, you always have 'different' experience.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    As said mate, getting your codes read is the best place to go to with this cars electronics, but when it comes to the CIM sometimes the codes can point you in the wrong direction so HERE's a couple of things to check for free before you move on to codes.
    My problems were the same as yours and it came down to a simple dirty ABS plug, but TBH im sure this problem was sorted on 54 plate cars, but as said its free to check.
    HTH
  1. ABS & Traction control lights on?
    By keithsimmo in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2013, 20:17
  2. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  3. traction control and abs lights on....?
    By jungle in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2010, 21:22
  4. a.b.s. traction control lights
    By simplesi in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:40
  5. Abs & Traction control lights on
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 16:17
