Results 1 to 10 of 20
Thread: Engine light help asap
    Regular Member VikingLammy's Avatar
    May 2012
    Woolwich
    Vehicle : Vectra Vxr
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Default Engine light help asap
    going down the road 2 miles my 1.8vvt sri vectra suddenly starts shakeing as im putting on the gas, then realise my engine light has come on. This is exactly what happened to my mk4 astra and had found out it was a spark plug. Ive just check them and they still look really good. Anyone got any ideas what his could be. My wifes pregnant and is due tomorrow so really need this sorted asap!!
    Barrow In Furness, Cumbria
    Need to get the codes read, otherwise you could be wee'ing in the breeze!
    Could be coilpack though if it felt like it did when it was a spark plug.
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    I just bought one off of ebay, should be here monday. Garages charge loads dont they?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    What you're describing could most probably be a plug going off, or a coil pack failing.
    Really need the codes read for a definite answer though. Main dealers rip you off for fault code reads. Try a smaller independent if you're in a hurry, should be cheaper.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    You can do the pedal test on the 1.8 to read the codes
    Jul 2011
    teesside
    Engine : Z18XER
    some fault codes here http://www.vectra-c.com/forum/showth...s-Vauxhall-TIS coil pack for 1.8vvt is around £150 from the stealers. I got non genuine from local parts place for around £53
    how to http://www.vectra-c.com/forum/showth...-any-Equipment
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    ive done the pedal test but doesnt flash or nothing, will take a visit to the garage in the morning
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Had the same problem.
    Changed plugs to no effect.
    Bought a second hand coilpack and it sorted it.
    Your problem could be :-
    Maf Sensor faulty
    Blocked up fuel filter
    Coilpack
    Spark plugs
    Im betting on coilpack or fuel filter though but thats just a guess. Im no expert.
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    my scanner come this morning, plugged it in and says p0302 cylinder 2 misfire detected. Is this spark plug? they looked fine to me tho
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Well id definitely try a set of plugs first, really not worth changing just 1 unless you've changed them within the last couple of months. If that doesn't help, its most likely the coil pack.
  1. interior light help asap please
    By simplesi in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2012, 17:06
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Emmissions light on. Help needed asap
    By stokie-lee in forum Engine & Drivetrain
    Last Post: 29th July 2010, 12:00
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
