Results 1 to 10 of 13
Thread: Noisy DMF or Belt?
    Oct 2012
    Swansea
    Default Noisy DMF or Belt?
    Hi Everyone,
    I'm getting a rattle when I rev my engine when cold. When the engine its warm is not more noticeable.
    The clutch has a bit of noise when depressed but I wouldn't say it was very noisy.
    1.9 CDTI SRI 150
    Here is the video of the noise I uploaded to Youtube
    If anyone is wondering if i've had the codes read due to the car with spanner light, yes I have and it's because it needs new glow plugs
    Aug 2012
    basingstoke
    DMF id say mate
    Engine : 1.9 CDTi
    Do the same think with the clutch fully pressed.
    If it doesnt do it then yes its the DMF
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    DMF
    Oct 2012
    Swansea
    Yep the noise goes when the clutch is pressed. Pretty strange that it only makes the noise when the engine is cold. Surely if a DMF is on its way out it should be making a noise all the time. Plus i've not got a noisy clutch.
    I only bought the thing two weeks ago so the previous owner must of know it was on the way out. He probably warmed the engine before I test drove it, he seen I had small children as well. some people have no heart.
    Regular Member John Bishop's Avatar
    Oct 2010
    Mine sounded clattery a bit like that and the gear change became very awkward, almost like having to double declutch to change gear. Had dmf, clutch kit and csc done. Clutch looked fine, dmf seemed ok but csc just fell apart.
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    Does it rattle when just revving it or when idle. Sometimes it could be the tensioner connected to the alternator, get someone to rev it while you under bonnet and see where the rattle is coming from. If it is the dmf the rattle should always be there not just when cold. Going from my experience the and Ive had a few it does snd like the tensioner but check for yourself under bonnet
    Oct 2012
    Swansea
    it only rattles when revved or when engine is switched off
    Oct 2012
    Swansea
    UPDATE
    My dmf has gotten so bad that its wreaked my starter motor. So I'm biting the bullet and getting it done asap. I rung around a few garages and most of them either say that they won't do it or it will cost £800+. But one garage recommended some other garage as in his words "they do loads of them" So I ring them and they've given me a supplied and fitted quote for LUX make of £523..... Sounds to good to be true.
    Carnoustie
    How come your spanner light on when revving?
    Ronnie
  1. Noisy fan belt
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 08:44
  2. Noisy Aux Belt-any ideas?
    By Croxley in forum Engine & Drivetrain
    Last Post: 2nd January 2011, 00:10
  3. 2.0 t noisy belt tensioner
    By Matt Cutler in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 23:30
  4. Noisy Aux belt on cold start 2.0T
    By neilbroad in forum Engine & Drivetrain
    Last Post: 27th January 2009, 21:00
  5. Noisy A/C
    By multi in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 20:03
vectra 2.0t aux belt tensioner www.vectra-c.com
