Likes Likes:  2
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: auto electrician
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default auto electrician
    how much does it cost to take car to an auto electrician?
    Dec 2011
    Seaham
    It depends what you want doing? Some may offer a free fault finding service, others may charge you a flat fee for X number of hours? Others will waive the initial fee if you have the repair done by them. Ring a fw up and tell them what the problem is and ask what they would charge to sort it out?
    Nov 2011
    Buckinghamshire
    thanks Ben, i did ring a few and explained what was wrong (bettery light - long story!!) and they all said 'depends what we find' and didnt give me a price
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's usually not as simple as ringing a garage and asking for x part to be replaced
    as it could be a number of faults.
    whats up with it?
    Nov 2011
    Buckinghamshire
    cut a long story short
    end jun/beg july battery light came on & lost everything - alternator failed so new one fitted plus new aux belt.. 6 weeks later battery light on again so got new battery, 2 days later battery light again so another new alternator, 6 weeks later battery light came on AGAIN!! all voltage checks when batt light is on and engine running is 14.3 .. with everything on 14.19.. battery light is tempremental and some journeys will not come on at all( can be a 30mile trip).. other times can be within a mile and its on.. its been like it for the past 4 weeks and we have done between 200-250 miles while its been like it.. i keep the multimeter in the car and everytime light comes on i check the voltage!!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd be hunting for a possible loose earth as you've pretty much eliminated the usual suspects.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    If you're thinking earths to be at fault there should be 2(?) earths on the right of the fuse box under the bonnet, between the fuses and the wing, or on the panel near there.. are they secure?
    (apologies for vagueness, the prefacelift may be laid out slightly different from mine)
    HTH
    Stuart
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    When the battery light comes on use a jump lead from battery negative terminal to a decent earth point on the engine (lifting hook is ideal) and see if the light goes out.
    Quote Originally Posted by SarahP View Post
    Were these 'faulty' alternators diagnosed and fitted by the same place/person? Just find it difficult to see that an alternator failed after six weeks and if it did then surely it would have been replaced under warranty?, or was that the case (that it was under warranty)?
    Nov 2011
    Buckinghamshire
    the alternator was changed because it had 12 months warranty so was just simply a case of swapping.. (and because when I wrote on here most answers were pointing to the alternator again).. but surely it cant be alternator as wouldnt it have packed up well before now? the auto electricians I rang today all said that even if the alternators were at fault they should have lasted more than 6 weeks,
    It doesnt matter what Im doing either when the lights come on, sometimes it comes on when just driving (not using anything, nor breaking or indicators) sometimes I could have the wipers on.. sometimes just by breaking... but oddly I can be driving with everything being used, and it wont come on
  1. me thinks i need a auto electrician in or around the blackpool area
    By 6009tristanb in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 19:32
  2. auto electrician
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 14:56
  3. auto electrician leeda Area
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 07:34
  4. auto electrician
    By leelfc150 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 15:23
  5. anyone reccomend a decent auto electrician in kent
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2010, 00:16
