Thread: side light warning help plz
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default side light warning help plz
    Hi guys, what it is is that my left/ passenger side sidelight keep showing bulb failure now and again and when I turn the steering wheel half lock either way, I have canbus leds in and ive swapped them and it still does it on the same side, it doesnt do it with normal bulbs and its done it from when I got the car, ive had it from 6 months old its a 2008, just to see if anyone had the same problem or might think what it is. I dont think its a loose wire but i may be wrong. Cheers
    Dec 2011
    Seaham
    Think there is your answer in your post, it does it with LEDS but not with normal bulbs. I would say the canbus leds arent fully compliant.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Yes but as I said its only the one side that does it, left side. If I swap it its still the left side.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    this is normal, its always the left side, not sure why, but it just is..
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need some resistors mate
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Had exactly the same when I had LEDs in my sidies.... and that was with at least 3 differing types. The failure warning was totally random timewise and always the left lamp. I think it's just the sequence that the check system works.... it hits the left lamp first.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Cheers guys thats all I needed to know jst in case there was a problem, as said above the resistors should sort it, cheers!!
    Regular Member renodci's Avatar
    Kent
    My Vec gives this random warning for that same bulb as well - but mine are standard bulbs (as far as I know). Strangely, I don't ever seem to get this warning when the lights are on.
  1. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  2. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  3. Possible cure to led side light bulb warning
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2007, 17:37
  4. LED Side Lights, Warning notice
    By tonyt in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2007, 19:56
  5. Car Pulling To One Side after Warning Light Has Been On
    By willc01 in forum Handling & Braking
    Last Post: 12th October 2006, 21:18
